helmet wind buffetting issue
I solved it by adding the lower fang type wind deflectors. Had to modify them a bit to clear my quick release mounts on the non-HD windshield. But it made a difference like night and day.
Here is my take on what is happening:
With a windshield on your bike, it does stop the wind that is coming right at you. Problem is that produces a low pressure area behind the windshield that just sucks the wind up from below. Or actually the wind from below is just rushing up to occupy the low pressure area.
You can test this by just laying your left arm across your chest while riding, and it will be calm around your head.
I could also stop it by putting my feet up on the top of the engine guards and holding my legs tight against the gas tank.
I could also, while riding normally, put my hand out flat on either side of my gas tank, and it would feel like powerful fans blowing the air up.
Adding the lower wind deflectors deflects the high pressure air from below so it doesn't rush up into the low pressure area behind the windshield.
Your helmet has absolutely nothing to do with it.
Some guys say that you have to cut your windshield right down or go to a Windvest windshield.
These 2 options will work to a point, just because either way the windshield is much smaller than a stock shield, so there is a lot less of a low pressure area behind it so the air from underneath is not rushing up nearly as much. The trade-off is that they don't block nearly as much wind form the front either.
So to solve your problem, keep your windshield as it is and your helmet and add some lower wind deflectors.
You could also get a Jack's Flaps vest, but you will probably still be getting the wind on your lower chest area up to where the flaps are located, but it does look like a viable solution also. Does any body have one of these vests? I would like to see a review or comment from someone who has tried one.
To see a video of what is happening with the wind buffetting, go to http://www.jacksflaps.com and click on the video link icon right below the picture of the vest. The video explains and shows you what the problem is.
Think I will try deflectors.
Dam..just another trip to store but spent many years without a windshield and really like it on long trips.
Thanks Again
Simple test to see if a Jackflaps will help, as seen on the website video, is to hold up your arm to chest level while riding, if you feel a difference, then Jackflaps works. Since it's adjustable via laces on the sides, sometimes I wore it over my jacket, especially on the freeway.
Riding a SG with fairing nowadays, still keep the vest cause of the patches.
Treasurecoastdj@aol.com
