A buddy of mine works for a company that designs and markets traffic lights and the sensors. He says that if your bike doesn't set off the (under asphalt type) sensor, that its the fault of whoever installed it. Usually due to it being too deep. I asked him recently about the "trigger" devices for bikes, and he said that they were a complete scam. That it is physically impossible for them to have any effect on the in-street type triggers.
I've heard that, too.
I saw the parts counter guys telling a guy that they were a scam; they just stock them because people want them and buy them. The guy bought it anyway. Go figger......
I commute to DC on my Fat Boy Lo and currently I have no issues entering a parking garage requiring keycard access (as long as I go to a specific entrance). However, the current garage is closing and next week I am being moved to another parking garage that also requires keycard access. I'm worried that my bike won't trigger the magnetic loop (I think that is what it is called) in the new garage. The garage hasn't been too helpful other than saying it depends on "how much metal you have on your bike." Have any of you had any issues with automatic gates and what have you done to fix the issue of a non-responding gate?
Thanks.
If you can see the strips in the road, park next to the strip line, not in the center and it should trigger even a small bike. Try it a few times and you'll soon get the hang of it.
I think it can depend on the bike, and what type of sensor the gate uses. On an old Zuki intruder I used to have, I run my entry card and have drop it in gear quick, and duck to not get hit by the bar. On my zuki m50 that I just sold, I didn't have that problem in the same parking garage, the bar would stay up until I passed. Although, I always rushed through it just in case. I did test it once and waited, and the bar did go down in about 10 seconds. The old intruder had more metal on the bike then the M50. I'm hoping to get a bmw soon and I will have to see if I have to duck. BTW, since neither bike had a place to drop the the card into quickly, and fumbling to get it into my pocket would take too much time, I'd swipe it, put the card in my mouth and drop into gear.
I tried to get into the hourly parking garage at DCA (Reagan National) on Sunday, but the machine would not spit out the ticket. Loops in the ground just would not recognize my bike.
Automatic Swing Gate Systems can be installed as a single or pair of gates. Single Swing Gate Systems are best suited for a gate opening up to 2.8mtrs wide. Once the gate opening is above 2.8mtrs wide we recommend a pair of gates to ensure secure locking of the motors when closed and trouble free operation. Automatic Swing Gates are best suited to sites where the driveway is level on the inside of the property for the gates to swing into the open position. Automatic swing gates are also ideal for gravel driveways as they do not require any components to be mounted to the driveway surface.
automatic swing gate systems can be installed as a single or pair of gates. Single swing gate systems are best suited for a gate opening up to 2.8mtrs wide. Once the gate opening is above 2.8mtrs wide we recommend a pair of gates to ensure secure locking of the motors when closed and trouble free operation. Automatic swing gates are best suited to sites where the driveway is level on the inside of the property for the gates to swing into the open position. Automatic swing gates are also ideal for gravel driveways as they do not require any components to be mounted to the driveway surface.
Basically it is a large powerful magnet that bolts to the frame of the bike.
I had a couple of traffic lights that I couldn't trigger. Went to Northern Tool and bought a package of magnets, round about the size of a dime, stuck four on the frame under the bike and haven't had a problem since.
There are two types of sensing systems used for traffic lights.
One is the loop type system which uses a loop of wire and operates at a tuned frequency, same thing as the metal detectors used for looking for gold and other stuff on beaches, just has a larger loop. When a large enough mass of metal is near, the loop will shift the frequency to signal presence. at some traffic lights you can see the rectangular cutout for the loop. Best positioning, IME, is being right on top of the wire with front wheel over the corner of the loop.
The other type of sensing system is "loopless" and uses a 3-axis sensor to detect small changes in the earth's magnetic field. an object with enough metal will cause slight distortions in the magnetic field and will allow the sensor to detect. Usually these sesnors are located in the middle of the lane and can't be located easily.
I designed loop type presence detectors for a company that makes rail yard equipment. Did a lot of testing as well. Don't know how a magnet could trip a loop type sensor since it's based on frequency. However, it's conceivable a strong magnet could trip the loopless type.
One tip I saw was to take a magnet out of a PC hard drive and glue it to bottom frame of the bike.
+1 JB weld it to the underside of the frame. Don't glue it to the oil pan or it will attract any metal in the oil to a single spot in the pan and then release it all in the oil when removed.
