Tank Emblem Removal
Old May 29, 2011 | 09:27 AM
aamodt22's Avatar
aamodt22
Default Tank Emblem Removal
We got a new bike and we want to remove the emblem and replace it with a new one. What is the easiest way to get the emblems off without damaging the tank?
Old May 29, 2011 | 09:34 AM
AZRenegade's Avatar
AZRenegade
Heat.
Old May 29, 2011 | 09:35 AM
Big_Al47's Avatar
Big_Al47
Use a hair dryer on low to soften the glue holding the emblem, the slowly peel it off. You may need to use fishing line or something similar to remove it. Then use goo-gone to remove the remaining residue off that tank
carpetride's Avatar
carpetride
Take some dental floss and cut thru the foam then use Goo remover or simple green to take off the leftover residue.
Old May 29, 2011 | 09:36 AM
skidder's Avatar
skidder
Use a heat gun and then run some fishing line under the emblem once you get it warmed up. The glue that's left behind will peel off but you'll burn your fingers because you have to keep it hot.
Then try some lighter fluid to remove the rest of the glue.
Worked on my bike just fine.
Old May 29, 2011 | 09:38 AM
aamodt22's Avatar
aamodt22
Thanks for all the quick posts
Old May 29, 2011 | 01:33 PM
nvsteve's Avatar
nvsteve
Old May 29, 2011 | 01:36 PM
jlasoftail's Avatar
jlasoftail
WD-40 works ok too and shouldn't ruin your finish. Just take your time and be VERY gentle or you will mark the paint. If you scratch the hell out of it, you should be able to wet-sand and polish, but taking sandpaper to your tank wont be fun.
Old May 29, 2011 | 02:07 PM
roadking2014's Avatar
roadking2014
fishing line and wd40
Magnut1
Jan 21, 2016 07:15 PM
converted
Mar 14, 2013 02:40 AM
Cruzados
Oct 8, 2012 10:01 PM
yank
Jul 21, 2009 02:21 AM
oiler47712
Jul 20, 2007 04:09 PM
