boot mark on exhaust
Old Sep 11, 2011 | 04:33 PM
Mongo1958's Avatar
Mongo1958
Originally Posted by chrskrngl
I used a razor blade to get the majority of it off very carefully and then a cleaner to wipe away the rest.
This by far is the most effective way to clean melted plastic and rubber off of pipes and heat shields. It is a procedure that takes a little practice (use a very shallow angle, as if you’re using a straight razor to shave your whiskers). Once most of the crud is gone I use mothers chrome polish. The pipes end up looking new with out any scratches.
Old Sep 11, 2011 | 08:25 PM
gobblerhuntr's Avatar
gobblerhuntr
No way it can get any easier than using Easy Off. Did that today to remove some pretty tough marks.
Old Sep 11, 2011 | 08:36 PM
MrMax's Avatar
MrMax
First reply was the answer I was going to give as well...Goo Gone or Goof Off. Finish with rubbing alcohol to get rid of any oily residual before heating up the pipes again.
Old Sep 11, 2011 | 09:34 PM
DannyZ71's Avatar
DannyZ71
I use Turtle Wax Chrome Cleaner. Works great. I try to get it taken care of while the pipes are still warm.
Old Sep 11, 2011 | 10:05 PM
banddirector's Avatar
banddirector
I've tried all the above and for me nothing works better than a little WD-40 and a razor blade on a cold pipe. The razor blade has *never* scratched my pipes; probably because the WD-40 makes 'em kinda slick. Any and all burned on stuff comes right off, and the pipes look like new ....
Old Sep 11, 2011 | 11:38 PM
Just Dave's Avatar
Just Dave
Nother vote for EZ-Off. I heat the pipes up and use a cotton rag. DO NOT touch your hot pipe with a micro-fiber towel...don't ask me how I know, just don't do it.
Steve Sportster
Jul 24, 2018 04:57 PM
wombat457
EVO
Apr 23, 2015 01:12 PM
Phillymiked
Apr 8, 2013 09:19 PM
Boozer
Feb 27, 2011 10:17 PM
bsambuco
Jan 23, 2008 10:37 PM
