Passenger Floorboards...??
Old Jul 25, 2011 | 07:29 AM
kerrycorcoran's Avatar
kerrycorcoran
Default Passenger Floorboards...??
Decided to add Highway pegs to my '11 Streetglide, and figured this was a good time to upgrade the passenger pegs to floorboards; will make the fiance happy.
Anyway, I have installed the Passenger Floorboards, but not 100% confident with the fitment of the inserts. The little rubber boots are seated around the pins, and I have tightened the set screw, but with a small amount of pressure I can easily pull the insert right off. Given the vibration on the bike I'm concerned the insert will work its way loose.
Any insight??
Old Jul 25, 2011 | 10:21 AM
remerson's Avatar
remerson
I installed them on my 11 FLHX and thought the same thing. So far I have put about 2k miles on and had no problem. Somehow they seem to stay attached???
Robb
Old Jul 25, 2011 | 01:02 PM
kerrycorcoran
I just test drove it into work (only about 5 miles on interstate) and they're both still there but just doesn't seem secure. At $85 a set I don't want to be replacing them often.
Old Jul 25, 2011 | 04:58 PM
dyna rider's Avatar
dyna rider
Default Boards
You can always stick the boots on with rubber cement (like kids use in elementary school). That way you can take them off if you want to.
Old Jul 25, 2011 | 06:20 PM
kerrycorcoran
The new style does not have the rubber boots; its a completely different configuration.
I added some soap (to help slip in place), and also, after a closer look, noticed there are 4 points that contact, not just two. Once I applied enough pressure and ensured all 4 points were in place the insert is pretty solid.
dylan199
Aug 15, 2017 11:47 PM
kberger
2014-2024 Touring Models
Dec 21, 2016 02:51 PM
scooter_trash_1
Touring Parts
Jun 2, 2010 08:23 PM
murd
Sep 6, 2009 09:08 AM
azharleyrider86401
Jan 13, 2009 11:15 AM
