torque wrench multiplier?
Old Nov 11, 2006 | 09:43 AM
DynaDave1450's Avatar
DynaDave1450
Default RE: torque wrench multiplier?
yes snap-on makes multiplier also costly on the pocket... so buy a good click type torque wrench and always double click ...you don't want a false click
Old Nov 11, 2006 | 10:01 AM
1flhtk4me's Avatar
1flhtk4me
Torgue multipliers will exceed the torque rating of the axle nut.
Just buy a larger torque wrench at Sears,home depot,lowes,etc-.
Old Nov 11, 2006 | 10:14 AM
campdreamer47's Avatar
campdreamer47
I maybe hi-jacking this thread but it was not my intention too. The thread is about Torque so here goes. I was using my 1/2" torque wrench on the spark plugs yesterday at the called for 18-21Ft Lbs but I did not get a click before what I though to be getting dangerouly tight so I gave up and left the plugs hand tight. What do you all think may have happened? Is 18-21 FT/Lbs thigter then I think or did the wrench just not click or could I have missed the click? Didn't want to twist of those plugs in the cylinder heads. I feel that a wrench this big is to big for this job anyway but my 3/8 is in inc lbs and don't go to 18-21ft lbs. Don't want to buy yet another torque wrench even if you can't have to many tools
Old Nov 11, 2006 | 10:22 AM
Hackd's Avatar
Hackd
The 'click' that we are referring to is also accompanied by a 'release' of the head on the torque wrench. If you didn't hear the 'click' you should have felt the 'release'.
I normally put a small amount of anti-seize on the sparkplug threads before I insert them. I torque to 18 ft/lbs. Sounds like you might have a 'dry' threads. And I'd also recommend that you purchase a 3/8" torque wrench calibrated in ft/lbs, the 1/2" model is giving you a false impression of what the torque is because of the longer wrench length.
Old Nov 11, 2006 | 10:35 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
better to use a 3/8 torque wrench on plus, i have both in lbs and ft lbs
Old Nov 11, 2006 | 10:36 AM
KeithB's Avatar
KeithB
ORIGINAL: carltex
I got a 1/2" drive torque wrench at Wally World for $28. Try that out. You will probably need it in the future anyway.
is it dail/click type?
Old Nov 11, 2006 | 10:51 AM
campdreamer47
I did use Anti-seize on the threads but I noticed you said small amount. I may have over done it. This could have caused the treads not to seat right I guess. I also understand what you mean that the large handle on the 1/2 torque wrench could give me to much leverage. Thanks I well get myself a 3/8 ft/lb torque wrench...why not. Do you think the plugs well be okay though or should I re-try torquing them?
Old Nov 11, 2006 | 11:07 AM
1flhtk4me's Avatar
1flhtk4me
ORIGINAL: campdreamer47
If the threads did not "seat" they would be stripped.
If too much antisieze was used,it would just ooz out past the plug body or be forced into the cylinder.
Old Nov 11, 2006 | 12:27 PM
GLewis's Avatar
GLewis
If you have a Harbor Freight close to you they have the 1/2 click type torque wrench on sale for $14.99 at this time. The are not the best but for know more than a bike owner uses one they work great. If you do not have a harbor freight close you can buy off their web site.
Glewis
Old Nov 11, 2006 | 06:48 PM
Rhubarb's Avatar
Rhubarb
216 inch lbs = 18ft lbs
