RE: Who uses their jack without strappinjg bike down to it?
Never used the straps, if you jack the bike up in the right spot it won't fall off without excessive force. Done all kind of wrenching, shock removal etc, no problems.
Don't be stupid...strap it down. You can be working on an area of the bike, and unknowingly pull on a nut or bolt with a wrench and then you have an ugly situation. Once it starts falling, it's almost impossible to stop it unless you are sitting on it. Nothing worse than looking at a motorcycle laying on it's side.
RE: Who uses their jack without strapping bike down to it?
I thought those straps were for holding my pants up while I'm bent over workin on the bike so the wife doesn't walk out in the garage and see my butt crack..............
I always strap down mine. Yes its stable without but I have kids who come in and touch things or lean on it while working on it. My mom has done this and my dad when visiting. It happens and they don't mean to. This always seems to happen when your on your knees working low. If the bike falls on itself thats one thing but on you, well it could be the end of your riding for a long time. I've tripped on things next to the bike and its the first thing I grabbed, glad to have the straps on. For the amount of time it takes to put them on its worth it.
For those who don't have straps I'm surprised. I never travel without them in the bags. I got a flat this past summer over 2 hrs from the nearest HD shop. A pickup pulled into the ditch, we loaded up, tied down and gone. Get the straps if not for your lift then at least for your travels.
MURPHY'S LAW: IF ANYTHING BAD CAN HAPPEN, IT WILL FIND A WAY TO.
O'LEARY'S CORROLLARY TO M's law: Murphy was an optomist!!
Strap that sucker... it's not a case of if , but when. Get cam straps, they are almost instant on and off. Ratchet straps are awful.
ORIGINAL: 60mike06FLHX
A few years ago during the winter I put my wifeâs Fatboy up on lift to do some work, I left it up and forgot it for a week, when I went back the jack had lost pressure and the bike was on the floor on its side. Broken tail light, bent fender, dent in tank and MAD WIFE.
I did not have the jack locked in the up position. I have gotten rid of that jack and replaced it with a Sears aluminum (worth the extra $) light weight if you carry it around. It has an auto lock however if I leave it up for any time at all I would use straps.
Don't strap the Sportster. If I am removing wheels or opening the forks I rope the frame to my shed walls on both sides so it cannot fall sideways. However, I am very careful when it's not roped. There have been some scary moments. This is more dangerous than riding it I think.
I strap mine. The jack was made in China and I am not betting my '04 EG's well-being on the quality of the hydraulic lift those Chinamen put together, nor am I willing to test the "stops" that are supposed to prevent the lift from going all the way down. When I lift a car with a hydraulic jack it goes on jack stands and the wheels on the ground are chocked. I like my bike a lot more than the Suburban, so strap away--it takes about two minutes. The guys in the Harley store have the best lifts available and they strap the bikes they work on--but hey, it's your bike.
