Thanks for the feedback / input. My friend is doing the work and his latest work was a police bike with 23k and tensioners were toast. I bought S&S 510 gear change kit, new adjustable SE pushrods and new lifters. Rather be safe than sorry and put an extra smile on my face! The last three summers have been slow with crap and new house and I'm looking forward to a minimum 10k/summer on my machine.
My 2006 SG has just 25k miles. From the sound I've been hearing for about 2k miles, my friend that works on the bike thinks it's the cam chain tensioner starting to go. I met another SG owner today who mentioned the same issue and the bike sounding like a "singer sewing machine"....he hit the nail on the head!
Anyone have the similar problem?
What are good choices for new gears/cam?
Should this problem be addressed immediately?
CL,
The way I look at it your engine is a ticking time bomb with those shitty plastic cam chain tensioners in there. IMHO, it is the TC88's one major design flaw. You never know when they are going to fail, and if they do, you're looking at major damage to your engine.
Some dude posted pictures of this exact thing on the forum a few months back, and it wasn't a pretty sight.
What you do is your business, but if you've got the money, my first choice would be gear driven cams. Next cheaper option is the hydraulic tensioner conversion kit. Least expensive would be to replace your current tensioners with new ones but if you do that, you're right back where you started worrying about them failing. Good luck.
Next time you change your oil cut the filter open and look for little pieces of ornge plastic and god forbid pieces of metal. I do this at every service.
That is what I did on my 03 Heritage four years ago and haven't regretted it.
I did the same thing on my Deuce. I could feel the mid-range torque difference.
That's the problem, they don't seem to wear consiistently. I checked mine every 10,000 miles (PITA every 6 months(!),) and at 70,000 they still looked decent.
At 81,000 the inside shoe had broken in two and the loose piece was caught between the chain and the spring ( fortunatley.)
With the milage and Timken Lefty bearing still in the 2000 bikes the gear drive was the logical direction.
As was suggested, check your run out. And at install, check the gear lash so it runs as quietly as possible. Too loose, it clacks, too snug, ir'll whine. S&S sells different sized pimion gears to match your needs.
