I must be missing something here. That statement is true for any stick shift be it a motorcycle, car or truck.
Wellll, not exactly. If you have ever sat at a light with one foot on the peg and the other on the ground for balance, you may have a moment when you begin to tip towards the side where your foot is on the peg. You have to put your peg side foot down to keep from falling over. Now if your peg side foot is holding the clutch pedal down and you begin tipping over, you have to either get your hand down to the shifter real quick or risk the bike lurching forward.
In a 4 wheel vehicle you really don't have the problem of loosing your balance, I think.
You are correct.. only a modified foot clutch with the over center spring removed was and still should be termed "suicide clutch". While we're at it, a tank shifter with all linkage removed and the shifter connected directly to the transmission is called "jockey shift". My experience was this '39 EL bobber.
Maybe we could rename the kill switch too. Seems a little over aggressive considering the bike restarts every time you use it. Maybe call it the "Rider actuated, painless, coma inducing, motor switch".
I think suicide shift phrasing seemed perfectly appropriate. What do you do on that VLD when you go to shift? You operate the foot style clutch then make the shift. It's not like you just ride along and operate the clutch from time to time without shifting. You make a decision to shift and use the clutch to facilitate that shift. Therefore the danger is in making the complete shift, not just using the clutch. My $.02
Met a guy once who was running an open-belt primary with a jockey shift. He was missing 2 1/2 of the last three fingers on his left hand. He said it happened so fast, he didn't really feel them come off. I think he was lucky his left foot didn't commit suicide as well.
I rode 3 different bikes with Suicide cluth and Jocky shift....
I usually had it in Neutral befor I came to a stop.
I did learn to stop and lean to the right with right foot down and left foot on the clutch....
You tend to ride mostly with one hand on the bars and one on the shifter....Especialy around town....
They do take some getting used to and are a blast to ride....
It's been my understanding that a true "suicide" bike was a foot clutch, jockey shift with no front brake.
If you catch a red light on a hill (think San Fransisco) and you slip the trans into neutral before you stop, you use your right foot on the rear brake to hold you in place and your left foot to hold up the bike.
When the light turns green you have to take your right foot off the brake and put it on the ground so you can push in the clutch with your left foot, slap it in gear and take off without rolling too far backwards. It's a tricky thing to do and that's why it was suicide.
If you have a front brake it's just a foot clutch, jockey shift bike because you can use the front brake to hold the bike in place. Even if your foot slips off the clutch the front brake will make the bike stall out.
>>It's a tricky thing to do and that's why it was suicide.<<
Sometimes on a hill I'd just roll backwards putting my back tire up against the bumper of the cage behind me. Of course that's when cages still had real bumpers and I looked a lot more menacing . . . LOL!
And everyone up-board is right. Most of what's called suicide shift today is actually just jockey shift.
Oughtta see what happens when you give a li'l ol' gal her first ride on a suicide/jockey and forget to tell her to always talk into your right ear. First time she talks into your left ear when you're coming to a stop and can't quite find neutral can get a wee bit exciting.
1972 XLCH - left side suicide clutch, right side jockey shift, left side throttle
1978 FLH - rocker clutch, hand shift, 3 speed w/reverse
1987 FLST - suicide clutch, jockey shift, Baker N1 shift top
2007 XLN - suicide clutch, hand shift (but now back to stock for THE MAMA)
thats the way I grew up , if your running a front brake ...it aint a suicide set-up
I also think some folks get a lil nit picky ...I always just figure suicide shift came around because of the set-up ...not an actual part.
that said , I love my jockey, can't explain why....it just feels right
My old 1942 "45" still had the rocker clutch. I never had a problem with it. As said above, it was a little tricky on a hill with no front brake. My cable was broken. Cushman motor scooters had suicide clutches and jocky shift, but it was also with a centrifical clutch.
