Cruise Control
Old Oct 8, 2011 | 06:49 AM
DaveMK's Avatar
DaveMK
Default Cruise Control
Isn't cruise control suppose to shut off when you hit the front or rear brake? It shuts off when I roll the throttle forward and if I pull the clutch in. I hit the brakes and the bike kept accelerating.
Old Oct 8, 2011 | 07:42 AM
honestbob's Avatar
honestbob
You have something wrong there. Mine will go off when I hit the clutch, front brake, rear brake or roll the throttle foward. If yours doesn't release when the brakes are applied, I'd get it looked at. Seems unsafe to me.
Old Oct 8, 2011 | 07:44 AM
CHILLLS's Avatar
CHILLLS
dumb question but do your brake lights work? when you use the front or rear levers?
did it all of a sudden stop working?
i would check the connections first.
Old Oct 8, 2011 | 08:06 AM
NDBadlands4-2's Avatar
NDBadlands4-2
Yes. Definitely get it looked at. Clutch, or either brake should get it to disengage. Have you looked to see off your brake lights come on? Also is it with either brake or just one that it will not disengage?
Old Oct 8, 2011 | 08:10 AM
jeffreydsilver's Avatar
jeffreydsilver
Old Oct 8, 2011 | 10:09 AM
DaveMK's Avatar
DaveMK
It won't disengage when front or rear brake is applied.
Old Oct 8, 2011 | 11:44 AM
XKnight's Avatar
XKnight
The HD cruise control on my Road King definitely disengages when the brakes are engaged. Unless you have some aftermarket cruise control I'd say something is wrong. Also sounds like a safety issue.
Old Oct 8, 2011 | 03:58 PM
Jrsess's Avatar
Jrsess
I wouldn't use it untill you get it looked at!
Piper250
Jul 22, 2017 08:44 PM
Lunchboxx
May 5, 2017 12:20 PM
Spowell928
2014-2024 Touring Models
25
Jun 1, 2014 04:09 PM
BigTasty
Jun 4, 2011 10:23 AM
Trock
Jan 7, 2008 07:36 PM
