Screamin Eagle Heads
Old Dec 1, 2006 | 05:15 PM
WEBBiker's Avatar
WEBBiker
6th Gear
Default Screamin Eagle Heads
Just purchased screamin eagle heads part #16592-99C to be installed on a 2001 Dyna with 1550 Flat Top Kit with 203 cams. After inspecting heads I was disappointed to find that none of the ports are polished. They are sprayed with the same coating that the fins are coasted with. Should I send them to the local machine shop to have the ports polished or will that hurt low end performance. What would you recommend? Thanks for the help in advance!!!
Old Dec 1, 2006 | 06:30 PM
notorious's Avatar
notorious
Default RE: Screamin Eagle Heads
Polishing is only recommended for exhaust side otherwise it will effect the mixture at slow speeds. Put them on and go.
Old Dec 1, 2006 | 07:55 PM
Bryan TTM's Avatar
Bryan TTM
i'd sell em i they were mine
Harleygunguy
Feb 25, 2020 05:36 PM
Baja555
Mar 4, 2018 07:53 AM
harley_djt
Apr 16, 2008 09:07 PM
drdave
Aug 3, 2007 07:36 AM
2stout4u
EVO
Oct 31, 2006 01:50 AM
