trouble shooting help '97 Softail
Old Dec 22, 2011 | 06:21 PM
driv3rx's Avatar
driv3rx
Default trouble shooting help '97 Softail
I have replaced the jackshaft on my starter,was grinding and hard to start,also replaced entire ignition,it had over heated and was fried,replaced stater and voltage regulator,and battery,also removed cleaned and rebuild kit in carb.,new spark plugs too.bike ran like new ,for 2 days,third morning went out to shop,started up fine,opened gate got on bike went about 5 feet and it died,try and try to rtestart no success.push back in shop get in truck go to work,afternoon get home go out to shop bike fires right up?ride around about an hour no problems.
next morning go out same routine same results .afternoon same thing starts right away.wtf???????/
mornings in upper 30's to low 40's,afternoon upper 50's to mid 70's.
any body have an idea? btw full tank of gas petcock open.
Old Dec 22, 2011 | 06:53 PM
RHillbilly's Avatar
RHillbilly
Could be ignition module
Old Dec 22, 2011 | 07:05 PM
BikerV's Avatar
BikerV
It does sound like an ignition module. You can also take the tank off and check the wiring to make sure a wire isn't rubbed through and grounding out. Especially that grey wire that runs from the harness up to the on/off switch. While the bike is running gently tug and pull the wiring harness at different points to see if the bike will shut off. I did have an 87 Softail that had a tankfull of rust. The rust would eventually clog the in tank filter and the bike would shut off. let it sit and the rust fell off the filter and it would start again.
Old Dec 22, 2011 | 07:35 PM
stokes's Avatar
stokes
Might sound stupid,but try tightening the ground cable on the battery.Had a similar issue on my 97 FXD and that was the problem.
Old Dec 26, 2011 | 07:45 PM
driv3rx's Avatar
driv3rx
ignition is new,battery cables tight.
believe it or not it cost a whopping .53 cents to fix,was vacume hose from pitcock to carb.
BC IAN
Jan 13, 2014 07:45 PM
shovelshort
Oct 17, 2011 12:48 PM
joe28
EVO
Sep 9, 2011 05:17 AM
fogcity123
EVO
13
Jun 19, 2011 12:24 PM
sandman7415
Apr 29, 2010 09:32 AM
