backfiring..need help
Old Jan 19, 2012 | 05:37 PM
Dite's Avatar
Dite
Default backfiring..need help
We bought a used 2011 Heritage for my wife from a dealer. The previous owner had the dealership install the Stage 1 kit with air filter and Vance & Hines Staggered pipes. They told us they tuned or flashed the on-board module for the Stage 1 kit.
When we bought the bike, we had the dealer install the Harley Smart Security system (#41000021A). They had to replace the module from what we were told.
They gave us the old module (#69991-11 BCM BASE Y-AXIS) back.
Should they have flashed the new module for the Stage 1 kit that was already installed?
Why does the bike backfire when we decel from speed?
Could it be they forgot to flash the new module after they installed the new module to compensate for the Stage 1 kit?
Old Jan 19, 2012 | 05:43 PM
heybaylor's Avatar
heybaylor
Did you ask your dealer this question ?
badwhine's Avatar
badwhine
Backfire on decel? Air leak? Lean condition? Modified exhaust and poor tuning?
Old Jan 19, 2012 | 05:55 PM
rooti's Avatar
rooti
OK, excuse this dumb question...I've never had or used a security system.
They replaced the EFI? The EFI is what holds the download and controls the way the engine runs. I didn't think they messed with the EFI to put in a security system.
If they did replace the EFI then they have to download again.
If your talking about another "module" then the bike needs a tuner, the stage one harley downlod is EPA approved and doesn't do a whole lot. Chances are, the bike is running to lean.
Old Jan 19, 2012 | 06:19 PM
chamokie's Avatar
chamokie
EFI is Electronic fuel injection, what controls down loads is the ECM Electronic control module. Correct me if I am wrong.
I had popping on decel, the muffler clamps were not tighten up, the bolts had come to the stops but not applying pressure on the mufflers. Put new clamps on the mufflers, issue gone. FWIW
Old Jan 19, 2012 | 06:35 PM
rooti's Avatar
rooti
lloks like this part was a recall on your 2011. Did they charge you for the part?
Model Year(s):
H-D / SOFTAIL
2011
Manufacturer: HARLEY-DAVIDSON MOTOR COMPANY
Mfr's Report Date: JAN 28, 2011
NHTSA CAMPAIGN ID Number: 11V037000
N/A
NHTSA Action Number: N/A
Component: ENGINE AND ENGINE COOLING:ENGINE
Potential Number of Units Affected: 6,964
Summary:
HARLEY-DAVIDSON IS RECALLING CERTAIN MODEL YEAR 2011 SOFTAIL MOTORCYCLES MANUFACTURED FROM JUNE 7, 2010, THROUGH OCTOBER 8, 2010, WHICH HAVE HAD A SECURITY SYSTEM KIT INSTALLED AS AN ACCESSORY. THE BODY CONTROL MODULES (BCM) INVOLVED ARE PART NUMBERS 69991-11 AND 69993-11. THE BCM HAS A CASE THAT MAY NOT HAVE BEEN PROPERLY SEALED DURING PRODUCTION. AN IMPROPER SEAL MAY ALLOW WATER INTRUSION INTO THE BCM WHICH MAY CAUSE ENGINE STALL.
Consequence:
AN ENGINE STALL WHILE IN TRAFFIC CAN RESULT IN A CRASH, WHICH COULD LEAD TO INJURY OR DEATH TO THE RIDER.
Remedy:
HARLEY-DAVIDSON WILL NOTIFY OWNERS AND DEALERS WILL REPLACE THE BCM FREE OF CHARGE. THE SAFETY RECALL IS EXPECTED TO BEGIN ON OR ABOUT FEBRUARY 21, 2011. OWNERS MAY CONTACT HARLEY-DAVIDSON AT 1-414-343-4056.
Notes:
OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV (http://hdtalking.net/+CSCO+1h7567676...792E7163662E66 676E67722E69672E6866++/exchweb/bin/redir.asp?URL=http://www.safercar.gov/)
Old Jan 19, 2012 | 06:42 PM
Shredding rubber's Avatar
Shredding rubber
Either the a/f is too lean(EPA dealer download=total waste of money just to up the rev-limit) or you have an exhaust leak.
I have a fuel pak(pos) and slip ons. The decel pop was so bad I thought I had serious problems. I checked exhaust for leaks(found 1 at head,rear cylinder). Didn't cure the issue but did help somewhat. Contacted Vance and Hines. They gave me new numbers,still had problem,email v&h and got new numbers,still popped,email v&h got new numbers. Went through this about 10 times,started adjusting the map myself. Finally tuned the decel pop out but the bike was a dog. Was getting walked on by stock 88s,but it didn't pop.
Contacted v&h again. Told em their product was junk. Bought a pcv. Installing it sometime next week.
Moral=
could be an exhaust leak and the lean dealer download could be multiplying the effect. Don't bother with the dealer EPA approved junk,or waste your money on a fuel pak. You have a couple options. You can get the bike dyno tuned which will get the most out of your mods even though there aren't many or You can get a tuner with a map already on it from one of the great sponsors here or you can get a tuner with the auto-tune feature and never think about it again.
The auto-tune module will also compensate for new mods,and is constantly monitoring the exhaust and will keep adjusting the tune til it's perfect. This is the best option but also the most expensive. They also have a feature that will change your tune with the flick of a switch. This is the route I am going. I will have 1 tune for city riding,richer to keep bike cooler and adjusted for max power. Then another for highway fuel economy,leaner but that's alright because I will be in motion.
The dealer download is a total waste of money. It's still EPA approved and only adds to the rev limit. A fuel injected bike will compensate for pipes and air cleaner but most carb guy refuse to even learn about fuel injection so they pay twice.
Old Jan 19, 2012 | 07:12 PM
dickey's Avatar
dickey
I believe the fuel map is controlled by the ECM & the security is controlled by the TSSM (Turn Signal Security Module) So I don't think it would have any efect.
workman482
Sep 29, 2014 08:00 PM
HDV-GLIDE
Apr 14, 2014 01:16 PM
Wardog86
Mar 28, 2013 01:07 PM
ashmarc
Dec 28, 2009 12:56 AM
2003king
Feb 18, 2008 07:48 AM
