Load Equilizer Question
Old Feb 21, 2012 | 06:28 AM
Figstr's Avatar
Figstr
Default Load Equilizer Question
I'm thinking about going with LED turn signals on my softail and know I need a load equalizer. Will I need 1 for for each set of turn signals or just 1 for all 4? Also, looking at various websites, I noticed they vary in amps. Does it make a big difference if I get say a 4 amp equalizer vs. a 2 amp?
While browsing Ebay I noticed in-line resistors. Could these be used as well?
http://www.ebay.com/itm/LOAD-RESISTO...ht_1561wt_1159
Old Feb 21, 2012 | 07:36 AM
NOLAMike's Avatar
NOLAMike
Usually one equalizer works for all four directionals. Some LED directionals have a built in equalizer so an additional one is not needed. If you are looking around I recommend you check out Custom Dynamics; http://www.customdynamics.com/motorc...rn_signals.htm . That's where I got my LED turns, tasil light and equalizer. Couldn't be happier.
Old Feb 21, 2012 | 10:55 AM
JohnFlorida's Avatar
JohnFlorida
You can use the ebay resisters or you can get them at radio shack. They will heat up so you need to find a safe spot to install them. safest bet is a new turn signal madule
Old Feb 21, 2012 | 12:33 PM
nevil's Avatar
nevil
I use an equalizer from Biketronics, it's plug and play and handles all the sigs and tail light.
Good customer service, too. I had a unit short out after 3 years and they replaced it free of charge. I asked the rep why some other brands are much cheaper. He said that the others use resistors which heat up, like JohnFlorida said. I didn't ask what system they used but probably wouldn't have understood it anyway.
ChromeJunkie
Apr 7, 2017 07:47 AM
RicMF
Nov 16, 2014 06:58 AM
Rava
Nov 23, 2012 02:48 PM
monstead
Jan 22, 2009 11:30 AM
