How often to change helmets?
Old Feb 24, 2012 | 05:18 AM
saltydog1911's Avatar
saltydog1911
Originally Posted by DOMAPOI
I don't think they were putting the DOT on the back of them back then. Better not come into California wearing that one. LOL
I think that the ones that brought up the idea of having to replace your helmet after a certain amount of time are the helmet manufacturers.
Back in the early 70's late 60's, they had a DOT tag. At least the ones in NYS
Old Feb 24, 2012 | 05:22 AM
Iceman24's Avatar
Iceman24
Helmets, believe it or not, helmets actually have a life-cycle because the protective material breaks down. In most cases it's ~5-yrs, but no-brainer if it was damaged by accident...
Of course, some riders swap helmets as often as bikes...can't be caught riding w/o matching lid. Need to make a good fashion statement...
Old Feb 24, 2012 | 01:37 PM
BBStacker's Avatar
BBStacker
Agree with ICE, 5 years is the recommended. Your sweat will affect the foam of the helmet over time. Kinda like changing your pillow every few years.
Old Feb 24, 2012 | 01:46 PM
Blackfly's Avatar
Blackfly
Originally Posted by bikenut1957
If it hits the ground hard enough to seperate the insides then its time for a new one. I have a camo helmet (four wheeler) thats 16 years old, I really don't mind the flies because I think they're lucky. I wear it only when I ride with a bunch of Marines. I have a H-D half helmet, I wear it when I take half a ride. I have a 3/4 helmet..yep you guessed it. And then there is my wifes pink helmet......
LOL and anytime your head swells you need a new one. I think 5 years would be as good idea for alot of reasons, flies included.
The strap will weaken with sun light for certain -unless like me, you mostly ride at night.
Old Feb 24, 2012 | 01:48 PM
jeffreydsilver's Avatar
jeffreydsilver
Default Rule Of Thumb
When you put it on and can't stand the smell any more!
Old Feb 24, 2012 | 02:58 PM
Skeezmachine's Avatar
Skeezmachine
I have also read five years. It makes sense to someone like me who wears my helmet all the time and rides consistently. The amount of weathering that my helmet gets exposed to here in FL on the outside and the wear from sweat time on the inside can really take a toll. Padding gets worn down which affects both fit and comfort. Probably why some of the more expensive full face helmets let you swap out the liners and inside padding. My head is worth $100-150 every five years or so.
Old Feb 24, 2012 | 04:30 PM
p51bombay's Avatar
p51bombay
While the comfort liner (padding) does break down over time, it is the foam liner that is of concern, although it may look ok, over time it loses its ability to absorb impact and you won't know until you need it.
Old Feb 24, 2012 | 04:51 PM
Leftcoaster's Avatar
Leftcoaster
Got a different color for every day. Is that often enough?
Old Feb 24, 2012 | 05:01 PM
fat_tony's Avatar
fat_tony
Originally Posted by meathead1134
Is there a general rule of thumb how often you should change your helmet? It got me thinking today.
The crush foam in a helmet will degrade over time whether it is worn or not. Most manufacturers say 5 years. I would say ~7 years at the very most. Most quality manufacturers (Arai, Shoei, etc.) sell replacement liners. My Arai cost $500 so I want to get the most use I can out of it before I replace it. If you crash in a helmet it's toast, the crush foam does not spring back.
Old Feb 24, 2012 | 08:46 PM
fxdwg_rugby's Avatar
fxdwg_rugby
Originally Posted by p51bombay
5 years
Yes it's five years...
