[quote=chuckcash;9463942]I have conflicting information at present I'm using synthetic 20-50 in my 2010 sporstep 1200L I have used it since I bought it new is this ok to use I now have 12000 miles on it any feed back is appreciated[/quote
Check the search option. This topic has been covered ad-nauseum.
Hydrogen would give you better gas mileage. It helps fight gravity and you weigh less riding down the road.
Helium helps to a lesser extent
Hydrogen might have your wheels looking more like the Hindenburg. The only small advantage to nitrogen is better tire pressure stability. For racing applications this is important. For daily road use it would be impractical. Helium would offer no real benefit.
Check your tire pressure regularly and keep your pressure within spec.
You may be able to find this product marketed at greatly reduce prices labeled as AIR. (note: do not leave the krypton out of the blend or your tires will no longer be impervious to road hazards)
I hear there's a new company out of CA that sells kits that fill the tires with pot smoke. That way, if you ever break down and are waiting for a tow you can suck on a tire and have a good time.
