Anyone run into this?
Old Mar 5, 2012 | 09:25 AM
hdgzr's Avatar
hdgzr
Default Anyone run into this?
Changed my fluids over the weekend. Performed a cold oil check according to the manual prior to my ride to warm it up before changing; and verified the oil level after warming it up from the ride before I pulled the drain plug.
When I refilled the tank, all it would hold was 3 quarts. Started it for a minute to check for leaks and to fill the filter, and it still did not need any added. Rode for a bit and checked again, hot check on the dipstick was full. Did a cold check the following morning, still full. Book says it should take 3.5 quarts. Assuming this is my bike's "normal"...
Old Mar 5, 2012 | 09:40 AM
HDmikie's Avatar
HDmikie
Yep, my Fatboy is happy with just 3 quarts. Manual says 3.5 quarts.
Redbeard719's Avatar
Redbeard719
That last .5 qt isn't in the oil tank when you drain it. You'll never really get all the old oil out, unless you use a scavenger, and even then, you're just circulating the new oil through, and draining the old oil out of the oil return line.
As long as your oil checks show good, I wouldn't worry about it.
Old Mar 5, 2012 | 09:58 AM
Wide_Open's Avatar
Wide_Open
Last oil change mine took 3 qts also.
Old Mar 5, 2012 | 10:29 AM
hdgzr's Avatar
hdgzr
It was just the first time I changed fluids on the Softail, so I was a bit cautious. Thanks for the replies.
Old Mar 5, 2012 | 05:35 PM
citykid's Avatar
citykid
Yeah, I put 3.5 in mine and didn't really pay attention to the oil pan itself. Then I see it really close to the top. Oops.
Old Mar 5, 2012 | 05:46 PM
Mortikus's Avatar
Mortikus
This may sound like a silly question, but did you change the filter at the same time? A deal of oil is in the filter and if you don't change it, the refill requires less oil. I try to always change the filter and typically the oil qty is about right, after warm up (and re-filling) the filter... I like put some in it as well as a bit on the o-ring before installing as well.
Mort
Old Mar 5, 2012 | 07:19 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Did HD change the oil qty with an oil filter change to 3.0 from 2.5 qts.? That's called a wet oil change. If you overhauled the engine and it was dried out real good then the oil fill would be 3.0 qts.
Old Mar 5, 2012 | 08:11 PM
oct1949's Avatar
oct1949
our 07 Heritage takes a little over 2 1/2 at change time.
I only fill it to 1/2 between the low and high marks.
Old Mar 5, 2012 | 08:12 PM
deadman77's Avatar
deadman77
Its easier to put it in than take it out. Go short and top it off.
