Remove Rubber From Pipes
Old Mar 8, 2012 | 10:03 AM
grog_lives's Avatar
grog_lives
Default Remove Rubber From Pipes
I have some marks on my pipes that I'm pretty sure are from a passengers sneaker sole. I've tried polish and kerosene to remove but they did not work. I've been told that 0000 steel wool may work and won't scratch the chrome. Thoughts and input?
Thanks,
Old Mar 8, 2012 | 10:21 AM
Pondskipper's Avatar
Pondskipper
You need the pipes to be hot when you clean them, I would avoid kerosene if you do that though.
Old Mar 8, 2012 | 10:26 AM
Silvertip's Avatar
Silvertip
Do not use steel wool. Go to a hardware store & buy a small copper pipe joiner or elbow.
Flatten it out and start scraping. It works really well & will not scratch the pipes at all. Pipes are best when cold for this fix.
Old Mar 8, 2012 | 10:28 AM
oct1949's Avatar
oct1949
I wouln't use steel wool. Steel against chrome ='s dull chrome.
Since I am too lazy to type all the answers out for U.
Try reading one of the 200,000 threads in the link below...
Then U'll see and learn how the rest of us do it.
https://www.google.com/search?source...1467l12.5l17l0
Old Mar 8, 2012 | 10:46 AM
grog_lives's Avatar
grog_lives
Thanks! Actually I meant to say acetone instead of kerosene. Sounds like most say to heat up and clean. Pipes are off bike so I guess I'll hit lightley with heat gun and go to work.
Old Mar 8, 2012 | 11:13 AM
ngoti8tor's Avatar
ngoti8tor
Put some Easy Off oven cleaner on a rag then dab it on the rubber and let it set for a while. DO NOT spray the Easy Off onto the bike because the overspray will get on the paint.
Old Mar 8, 2012 | 11:17 AM
hollowpoint's Avatar
hollowpoint
Just keep it on the chrome. I can eat other surfaces.
Old Mar 8, 2012 | 02:03 PM
beezer13j's Avatar
beezer13j
I have had good luck with nevr-dull on cold pipes
Old Mar 8, 2012 | 02:08 PM
toastman's Avatar
toastman
DONT spray easy off anywhere near your bike.
i learned the hard way. it got all the boot remains off my pipe but i was scrubbing easy off off of the black parts for weeks.
i scratched/dulled my pipe with nevr dull, and i had good results with steel wool
Old Mar 8, 2012 | 04:16 PM
Speedy818's Avatar
Speedy818
Mr. Clean Magic Eraser
