Essential tools
What are you going to do with more tools?....OK....maybe, a tire plug set and a cheap air compressor.
If you have a service manual and know how to use it a small set of tools may come in handy. I assembled my own tool kit but a good road set from Cruze etc will stand you in good stead.
I've adjusted the adjustable push rods on my 09 BargeGlide on the side of the road myself but I wouldn't recommend it to a novice or early learner (not saying you are either).
Where we ride, at least one bike in the group breaks down on any long trip. And its usually something that cant be fixed on the spot. Trying getting a tow in the Phils. Usually we end up having to cram a bike into a jeepney to get to a mechanic.
My FXDP was run pretty hard by po & is prone to "excentricities." So I don't feel safe leaving the neighborhood without carry all this:
* Hex Sockets & L-wrenches (both): 5/32, 3/16, 1/4, 5/16, 3/8
* Torx Sockets: 20, 25, 27, 40, 45 (3/8 & 1/4)
* Box End Wrenches: 3/8, 5/16, 7/16, 1/2, 9/16, 5/8,10mm
* 3/8" Ratchet Sockets: 5/16, 7/16, 1/2, 9/16, 10mm,14mm
* 3/8 drive rachet, 3" extension, adapters 1/4 to 3/8 and 3/8 to 1/4
* 6" Cresent Wrench
* Blue Threadlocker
* 6" Needle Nose Pliers
* 2 Cheap Champion Spark Plugs & gap tool
* 6" Needlenose Channel Locks
* Ratcheting Screwdriver & assortment of slip-in hex/torx/phillips/spade Inserts
* Leatherman Multitool
* Assortment of 10" zip ties
* Roll Electrical Tape
* Cheap Volt/Ohm meter
* Set of cheap spark plug wires
* Spare Crank Position Sensor
* 9" Jumper Cables
* Tire Plug Kit
* Crank-to-Charge Flashlight
* 5X5 Piece of painted 2X4 for coaster
* Camping First-Aid Kit
* Hand Wipe Rag
* Camping-type Hand Cleaner in Sealed Packets
I know, call me ****, but she's let me down once too often. I'm too cheap & hard-headed to sell er & buy something reliable.
* 6" Cresent Wrench
* Blue Threadlocker
* 9" Jumper Cables
* Tire Plug Kit
* Hand Wipe Rag
Now that I've done some wiring to the battery, my own brake pads and brake fluid bleed, spark plugs, clutch adjust, oils and air filter stuff etc I can fix a few more things first hand, and reading the manual about linkage, and various other mechanical parts I can easily deal with a few things based on theory - at least I think I can
- so carrying a standard pack on the front of my frame is a good idea. I always carry a camping water proof first aid kit which I've taken apart a few times, added a couple of things to, and understand how to use.The more you work on your own bike, the more tools you learn to use the more money you save and the better prepared you will become. The alternative is indeed a credit card and cell phone but even though I'm a newb who carries a cell phone and cc I don't want to be 'that guy' - the one who can only call for help. Working on my bike - even the high level light stuff is a fun part of the bike experience too, and a source of personal pride.
./enable boyscout mode ftw
* 6" Cresent Wrench
* Blue Threadlocker
* 9" Jumper Cables
* Tire Plug Kit
* Hand Wipe Rag
I'll take a guess and say you've had some trouble with crank position sensors in the past.
No spare head temp sensor?
