Top speed...in closed loop
Alternatively, to avoid trouble with the law, could you tell me what revs your engine is turning when you travel at 80mph in 6th gear ?
If you don't travel that fast just post rev and speed, as long as it is in 6th gear.
pls also indicate if you have a Dyna/Softail or Tourer.
The bizarre question will help a cheap fart like me adjusting the closed loop AFR, as my stile of riding isn't aggressive, I don't rev up the engine while I go through the gears, but I'm curious if at highway speed the bike would still be in open or closed loop. I suspect I use 99% the bike in closed loop, so I don't want to spend a fortune with a proper SERT+ dyno setup or similar, only to adjust the bike for a section of the rev range that I hardly use. What I like is a strong pull at low revs. I'll do the cam and proper tune once I'll be out of warranty on the bike.
Thank you!
