an air cleaner like the SE Heavy Breather, that allows you to position the elbow at the angle you want it?
for example, I run a SE Heavy Breather, and want to add lowers with speakers to my SG
I cannot do this as they occupy the same space, but if I could rotate the elbow up slightly it would comletely miss the lowers and the speakers and still be out of the way of my leg
so does anyone know of any company that makes some kind of elbow tube air cleaner like the SE heavy breather that you can rotate to the position you need?
with all the custom choppers and baggers out there, something has to be out there, and someone has to know about it.
if nothing else I may just drill and tap some new mounting holes on the mounting plate of the SEHB and see how that works cause I really don't like the look of the SE ventilator
I just looked on their website, and couldn't find it, but I could swear that Harley makes a Heavy Breather in a shorter version that will work with lowers.
they do, but it only works with lowers without speakers
