HarleyDroid working - Logging/RPM/MPH on cell phone
Old Sep 11, 2012 | 06:52 PM
  #51
JHL-ShinySideUp's Avatar
JHL-ShinySideUp
Originally Posted by Superfaber
Hi Guys,
I'm writing from Turin, Italy.
I'm HD Electra Glide Standard 2010 owner.
I've tried to follow instructions but seems that my motorcycles don't want give data signal on PIN nr.3
Anyone have any experience on my HD model?
Regards
Faber
The data rides on pin 2 from the OBDC, which connects to pin 3 on the Harley end.
Does that make sense?
Old Sep 25, 2013 | 01:20 AM
  #52
ZeroThoughts's Avatar
ZeroThoughts
Reviving an old thread.
Want to know if the same wiring set up (Harley side connector pin out -- ELM side connector) works for 2012 & 2013 Harley Dynas with CAN Bus systems.
Old Apr 14, 2014 | 08:23 AM
  #53
peter_reeves's Avatar
peter_reeves
6th Gear
Originally Posted by PatrickHenninger
It's HarleyDROID not iHarley. I doubt Apple would ever let software like this through their stringent filtering. Google (Android) allows open-source software to go into the Play Store (Android Market.)
Here's a page that will help anyone needing cable info...
https://github.com/stelian42/HarleyD...leyDroid-cable
The ELM327 Bluetooth Module can be had from Amazon, eBay, or DealExtreme.
Looks like there is a new one that works wirelessly on Apple iPhones and Android called RPMitUp.
Found a youtubes and it says it does HP and torque calculations also:
Old May 5, 2014 | 03:57 PM
  #54
bregmanr's Avatar
bregmanr
Stage II
Default 2014 FLHTK CAN BUS question
Here is a picture of the connectors on my 2014 FLHTK:
There are 2 possible connectors, both have more than 4-pin plug. My question is: which of the 2 plugs is the one to use to connect to the CAN BUS? Also, does anyone know the make/type of connector I need to use as well as the pinouts?
TIA.
Ron
Old May 6, 2014 | 04:18 AM
  #55
ZeroThoughts
Harley Droid does not work with the HD Canbus system.
Not sure if the RPMITUP program has any details regarding working with Canbus system.
There is a paid app, which provides a cable alongwith the app and they claim it works with Canbus systems.
Old May 6, 2014 | 12:14 PM
  #56
bregmanr's Avatar
bregmanr
Stage II
ZeroThoughts: Any idea what is the name for this app?
Also, is anyone on this forum familiar with the 2014 CANBUS wiring diagram or which of the 2 connectors is used for CANBUS connection?
TIA.
Ron
Old Jul 25, 2016 | 05:01 PM
  #57
miketimer's Avatar
miketimer
6th Gear
Finally got some time with a new 2016 HD Breakout that uses the CAN BUS system. We got a dashboard that can display the speed and one that can display the RPM. That's probably going to be the limit of what we can do for a while because of the amount of data that is being processed. Check it out:
Sash302
Aug 28, 2009 09:04 AM
sickwithit
Harley Davidson Videos
38
Jun 21, 2009 08:57 PM
