Best solvent to use
Old Jun 13, 2012 | 12:35 AM
Debronc's Avatar
Debronc
2nd Gear
Default Best solvent to use
I am in the process of changing the primary chain case gaskets. The manual says to clean the case with a solvent then be sure to dry it. I am looking for some advice on which solvent will work best to clean the case. There was a leak which is why I am replacing the gaskets so there is a good amount of oil/dirt on the out side case. Thank you.
Old Jun 13, 2012 | 01:07 AM
azblackbird's Avatar
azblackbird
I use mineral spirits and a parts brush, or solvent gun.
Old Jun 13, 2012 | 07:16 AM
TheGeek's Avatar
TheGeek
I use brake clean....cleans well and evaportates quick. Use the red can (I forget the name)
Old Jun 13, 2012 | 08:46 AM
oldairboater's Avatar
oldairboater
I use alcohol. Same as I use to remove oil on surfaces I plan on painting. Everything mentioned above will work but some of them seem to be more toxic.
Old Jun 13, 2012 | 09:44 AM
Debronc's Avatar
Debronc
2nd Gear
Sounds good. Thank you, I appreciate it!
Old Jun 13, 2012 | 09:46 AM
vincentostapowich's Avatar
vincentostapowich
I use Brake clean on anything i dont want to have a film on after its cleaned,like for instance cv clutches.
Otherwise thinner works great and i keep a bucket of it for washing carbs out etc.
Old Jun 13, 2012 | 09:47 AM
1flhtk4me's Avatar
1flhtk4me
I use brake cleaner or gas on parts like that.
Phil_Barone
The General Motorcycle Forum
May 18, 2010 01:58 PM
waynemags
EVO
May 30, 2009 09:57 AM
chrism84
Detailing
Mar 19, 2007 09:10 AM
