Keep in mind, you don't need to lean the bike very far to turn in 18ft, let alone 24ft. I'd bet your problem is not the lean but, lack of clutch/throttle rear brake control. Mainly clutch/throttle(friction zone). Here's a test for you to see where the problem is. Mark out a 34ft circle. Then turn inside that circle with the bike straight up and very slowly, 2mph or very slow walking pace. If you can't do that, It's the friction zone rear brake thats your problem. Practice all the friction zone exercises then the slow cone weave. Then set up your u-turn at what ever distance you feel comfortable. Your speed in the u-turn should be 5 to 7 mph. Making an aggressive dip as you start the u-turn insures enough speed to complete it. As you get more confortable turning, narrow the u-turn space until you can do it in 18ft.
After having read the book and watched the DVD I took the course in Pensacola,Fla and it did help a lot.I managed to complete all the drills without dropping the bike under the professional supervision of the instructor and his wife.I would like to do it all over again,it was fun.
Panic is not your friend. Why do you panic? You have to ask yourself that and decide if a motorcycle is the right thing for you. Fear of dropping the bike should not be a factor. Hope you learn to get past your panic and learn to do the maneuvers that will make you a better rider.
Unfortunately it wasn't. I was unable to re create the smooth effortless moves that allow a u turn in a 24 foot box. They say practice makes perfect but I need a lot more practice.
I've found that the key to really tight turns was the use of the "dip". That first exercise that they go through very quickly is supposed to give you a feel for rolling that weight from side-to-side using their dipping method. When you watch the turning exercises later in the DVD, they often use a dip or in the case of a U-turn two consecutive dips to initiate the turn. Once the bike is leaned over (even just a little) keep the power to it. When you practice the U-turns, try the double dip. It really helps.
The bike turns best while leaning, not strait up with the wheel cocked over and duck-walking it through.
I've been practicing myself. Shift your weight to the outside of the seat, turn the bars where you want to go. No counter-steering here, it's direct steering. You need to keep a constant pull on the engine by using the friction zone of the clutch, and a little rear brake may be necessary too. STAY OFF THE FRONT BRAKE. The most important part after all that is NOT to look at the ground, but in the direction you want to go.
I'm pretty good at it after some time practicing, but for fun I do it before I park when I get home from work, or if I have time, before I leave.
This guy is very smooth, but I think his tape measure is broken. No way that's a 15 foot box. More like 18 feet. Parking spaces are generally 10 feet wide.
Some of the best advice.
Do not panic and trust physics. That bike doesn't want to fall any more than you want it to fall, at least if you're giving it gas.
Don't fight the bike. . .that bike will win. Work with the bike.
Be at one with the bike. Just don't get too close. Hot mufflers burn.
My .02 - I bought the new ride like a pro dvd watched it all the way through twice, then got some very cheap cones from the amf and went out to a local school and practiced with a couple of buddies for a couple of hours. It was totally worth it, I've used what motorman teaches, on my rides several times, and feel way more confident making the tight u turns.
Not to be argumentative but he did say "seem to panic". I would guess it's not so much panic as it is a fear of dropping his bike(at least that's my take).
Everyone knows that no one wants to drop their pride and joy for numerous reasons. But we all know that it does happen and to some that fear is always in the back of their mind until training and practice overcomes that fear. watch
If ya watch the video one of 1st things you see is how to pick up your bike "if" you drop it. It's obviously there for a reason....People can and do drop their bikes.
I took a course a few years back "Streetmasters Precision Cornering Motorcycle Workshop". At one point the class you had to to make a "U" turn from a standing stop (IE: Idling, bar at the lock left u turn and right u turn, no rolling turn involved). Having never tried that yes I was slightly worried about dropping it. Left was not bad made, right (my weak side on the bike) without even knowing I did it I grabbed the front brake, down went the bike. But after practice I could do it.
I guess even with the OP especially after seeing others doing it it was predominant in his thinking. Just a guess.
The average parking space is 8.5 feet wide. That would make 2 spaces about 17 feet wide. The cones on the right are way over a foot inside the lines. Also, add for the thickness of the cones on each side. This EASILY could be 15 feet or less.
I'm not sure where there are parking lot's with spaces that small, but they sure aren't in truck country! Around here, 10' is the rule. No way to tell by watching that video except to use the bike (8') as a scale measurement.
I still say no way, I'm not even sure it's POSSIBLE to do a U-Turn in 15' on a Harley touring bike. 16' yes, but 15'? They do have their limits.
