true duals
Old Sep 11, 2012 | 02:00 PM
jmn1960's Avatar
jmn1960
Default true duals
if i put on a set of true dual exhaust,, do i have to have the bike retuned? can i still use the screaming eagle slip on ? or do i have to change them out also,,? 2005 ultra classic,, 88 eng.
thanks
Old Sep 11, 2012 | 03:35 PM
cayers's Avatar
cayers
From what I understand, the re-tune is only necessary if you change out the AC also. As for the mufflers, that depends on the makers of the duals so you will have to read on what will fit.
Good luck!
Old Sep 11, 2012 | 03:36 PM
kanelakos's Avatar
kanelakos
I bought Vance and Hines true dual and they came with mufflers. As far as re-tuning, I believe if you change your intake and exhaust you must. If only one or the other .... no.
Old Sep 11, 2012 | 03:51 PM
Dew Me's Avatar
Dew Me
I thought TD's came with mufflers?
Replacement exhaust is generally less restrictive. Your bike needs a certain amount of back pressure. So if you replace exhaust only your performance suffers due to lack of back pressure. You can also blue your pipes.
Changing AC brings in more air, you need a tune to inject more gas to go with the extra air. This culminates into extra exhaust that requires the freer flowing pipes to keep proper back pressure. Otherwise it's a bit like the banana in the tailpipe.
They all go hand-in-hand, just do it all and get it done.
I'm not made of money, but I swear I'll never understand why this question keeps coming up. As much as these bikes cost you oughta be able to do a complete upgrade. If you can't then wait till you can.
Stryfe8822
Jul 12, 2014 04:43 AM
beefcake.
Screamin Eagle CVO Models
Jul 6, 2012 03:19 PM
tee895
Dec 23, 2011 09:40 PM
FLTR2008TRIKE
Jun 28, 2010 06:17 PM
Dax4800
Mar 14, 2010 10:47 PM
