Brake parts cleaner
Old Oct 7, 2012 | 03:11 PM
_Gir_'s Avatar
_Gir_
Simple Green can have a bad side effect with aluminum where it becomes hazy. Test it first.
Old Oct 7, 2012 | 07:06 PM
Dr.Death's Avatar
Dr.Death
Simple green can be diluted. I have used it on just about everything under the sun. I have used brake cleaner on my motor but hosed it off immediately. Be very very careful with any engine degreaser on any alloy.
Old Oct 8, 2012 | 12:47 AM
arcticharleyman's Avatar
arcticharleyman
Originally Posted by oct1949
Used both,, SG and Wheel spray on cleaner,, both do good job..
just dont use High pressure hose around the wheel bearings... Not good on them.
Unless you want to repack them.
Old Oct 8, 2012 | 06:10 AM
Harley Tim's Avatar
Harley Tim
Originally Posted by edilgdaor
I didn't say I don't use it.
I was just mentioning that I've heard somewhere that there's an organization (I want to say US Army, but I have no idea if that's really correct ) that doesn't use it on aluminum. Maybe it was a helicopter application- I really can't remember.
If I ever get a helicopter, I'll check into it in more detail.
This is a "True Statment"....I've worked as a "Contractor" Army helicopter mechanic for about 20 years now, and before that, Army Aviation for the same.
During "Gulf I" we discoverd severe corrosion issues with aircraft that had Simple Green used on them.
The outcome was, Simple Green or any other cleaner with s Citrus base was forbidden to be used. PERIOD!
It is especially harmful to alum. alloy materials, and electrical.
Hope this helps.
Best wishes....Tim(HT)
Old Oct 8, 2012 | 12:14 PM
Leftcoaster's Avatar
Leftcoaster
Originally Posted by Sammi
I haven't asked a dumb question for a while so here goes:
Will spray-on brake parts cleaner be OK to clean the cast wheels on by Low Rider or will it cause damage to the finish? (The rear rim is grimy and dirty)
I have non-detachable saddlebags so I'm looking for the easiest way.
Thanks,
Sammi
Plain old soap and water works best. A spoke brush or a brush that will reach the tight spots will help immensely.
Old Oct 8, 2012 | 12:28 PM
oldairboater's Avatar
oldairboater
I wouldn't use brake cleaner unless everything else didn't work. There are gentler cleaners that work just as well that might not react with anything else. I worry about overspray more than hurting the wheel finish. Anything I clean my wheels with will get rinsed off with water anyway then polished. Stay away from the bearing with pressure and anything that might degrade them. Lots of people don't realize that seals keep out grit and liquids till enough force is applied. OP, to answer your question. I use brake clean but only to clean brake parts. Even on my motorcycles but I remove the caliper to keep overspray to other parts at a minimum.
Old Oct 8, 2012 | 12:31 PM
edilgdaor's Avatar
edilgdaor
Thanks.
I'm kinda surprised. I don't usually remember stuff right.
Hope this helps.
Old Oct 8, 2012 | 01:46 PM
brenn's Avatar
brenn
Wouldn't bother me to use brake cleaner, but I regularly clean parts with carb cleaner or lacquer thinner, so that's probably not the way everybody would choose to go.
I did find out last week that if you peel the old year sticker off your license plate, then pur some lacquer thinner on a rag to take off the sticky stuff, the paint on numbers will just wipe right off.
Old Oct 8, 2012 | 03:22 PM
BBStacker's Avatar
BBStacker
Originally Posted by brenn
Wouldn't both me to use brake cleaner, but I regularly clean parts with carb cleaner or lacquer thinner, so that's probably not the way everybody would choose to go.
Old Oct 8, 2012 | 06:27 PM
Harley Tim's Avatar
Harley Tim
You can always go with the "Raw Look".....
While I had my tire/wheel Assys. off, I stripped off the coating with some aviation grade stripper (safe for use on Alum. alloys), and went after the wheels with a stainless steel wire brush.
It rendered a nice brushed look to rhe smooth surfaces, and cleaned the rough surfaces very well. After-words, I use a SS brush with a little Soft scrub, then touch-up the smooth surfaces with some Never-dull.
Works for me.
