Lean lookin plugs
Old Jan 30, 2007 | 02:55 AM
Tompop's Avatar
Tompop
Default Lean lookin plugs
I installed a Big Sucker AC on my Wideglide. 2003. I have SE ll's slip ons for exaust. The bike starts and runs great. a little sneeze from the carb when started, and then its smooth. Runs like a bat out of he**. A real noticeable difference. Occasional sneeze while riding. Warmed it up, rode about 40 miles, pulled the clutch and killed the motor. Pulled the plugs and they are white. (new plugs). Lean! I read a thread in DIY that says low jets are usually #45 or #46. I have #45. This is supposed to deal with idle to 1/4 throttle. Im wondering if I can richin the mxture by adjusting the air/fuel mix with the screw. Thats question #1. Question #2. Im kornfused now. To richin, turn screw in ( clockwise)? Im I right? I posted this in carb fuel..... etc. I was told to just put a # 48 low jet in. The DIY Thread said I could put in a larger low jet or adjust the air/fuel. Also to pull the needle out and put #4 washers under the clip to adjust the mid range. This is starting to sound complicated. Help!!! Any suggestions? [sm=confused06.gif]
Old Jan 30, 2007 | 09:00 AM
cajunman831's Avatar
cajunman831
Default RE: Lean lookin plugs
make sure they are gapped at least 0.040.the common gap for v-twins
Old Jan 30, 2007 | 09:13 AM
billnourse's Avatar
billnourse
If you are running a 45 slow jet you are going to be lean. Replace it with a 48, and replace the needle with one for a 1988 1200 Sprotster and you will be fine. This will adjust the fuel air mixture for mid range where you will normally be running. It has been my experience that the high jet, usually a 165 to 175, will be fine.
You are not going to do much for the mixture by messing with the idle screw. This is basically for idle and very little above. Just turn it 2 to 2 1/2 turns out from the bottom and you will be good. The further out you go the richer you get.
None of this is complicated, just time consuming. Get a service manual and the workings of your carb will become very clear.
Regards,
Bill
Old Jan 30, 2007 | 12:41 PM
Steeltown's Avatar
Steeltown
Up the slow jet to 48 and problem will go away
OneHarleyAtATime
EVO
45
Sep 23, 2021 07:56 AM
widegliderider
EVO
Sep 2, 2012 02:43 PM
tom lipke
Mar 2, 2012 02:23 PM
skr8pn
Exhaust System Topics
Feb 23, 2008 05:22 PM
rounder
Dec 31, 2007 04:49 PM
