I,ve got a o7 Ultra and 1100.00 to spend on exhaust any good ideals out there for the money ?
THANKS BO
Should have said I want to get the PCIII , header pipe I've heard Vance&Hines is a good one,&the Stage I kit .I have a set of mufflers .
Bassani Power curve with 511 Bassani mufflers! They PERFORM AND SOUND GREAT! Not to mention the appearance! I'm a Bassani dealer if I can help give me a call monday. 1-405-631-1218 GOOD LUCK on the choice! TOOLBOX
I have the rinehart slip ons, with your 07 having O2 sensors you might want to go with just a slip on unless you plan to go with a tuner and removal of the O2 sensors.
What type of air cleaner are you planning to run?
What type of EFI mapping system are you planning to use? PC/SERT?
Do you want to stay with the true dual look or are you happy with a 2:1 pipe?
What is your noise (road music)tolerance? What kind of cruising do you do? Two up?
Any engine mods planned in the future? 103 kit, cams?
IMO, unless you do a complete Stage 1 (pipes/ac/EFI remap)you are wasting your money. You must unleash the hidden tiger!
