What kind of oil for primary...
Old Feb 6, 2007 | 05:58 PM
85FXWG's Avatar
85FXWG
Default RE: What kind of oil for primary...
If your bike is under warranty, use whatever the dealer tells you to use....Come back and ask again after your warranty is over.[/align]
Old Feb 6, 2007 | 09:00 PM
Toyman's Avatar
Toyman
ORIGINAL: mp
Do not use syn oil for the primary. You would be throwing away money. Use whatever dyno oil is on sale- 5w30, 10w30,whatever.
ATF works fine and is helpful in determining if oil leaks are engine, primary or tranny.
The splash lube environment in the primary doesn't require a super special oil.
I totally agree with this.
Nothing here needing that kind'a lube!
Old Feb 6, 2007 | 09:12 PM
thumper05's Avatar
thumper05
RED LINE MTL in the primary ..works like a dream..change it once a season
Old Feb 6, 2007 | 10:13 PM
wvrider's Avatar
wvrider
ORIGINAL: Clammy
I use Amsoil 20w50 in my primary. No problems for me.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Same here
Old Feb 6, 2007 | 10:18 PM
HD7585's Avatar
HD7585
I use a lighter weight for the primary 20-40 amsoil 20-50 in the engine.......Thats what Amsoil recommends
Old Feb 6, 2007 | 11:15 PM
Mac57's Avatar
Mac57
DO NOT use ordinary car engine oil on sale at Walmart. Many automotive oils use friction modifiers which are not compatible with wet clutches. Use only lubricants reccomended for the primary chain case. The H-D formula+ is great. Amsoil, Mobil-1, or Redline if you prefer synthetic. Right now I've got Syn3 in my primary because I just happened to have a couple bottles on hand. It's just fine. I use Amsoil 20-50 in the crankcase and Redline Shockproof in the trans. Other than lubricating, primary oil also cools the clutch. Another reason to use synthetic since it handles heat much better than Dino.
Old Feb 6, 2007 | 11:22 PM
57springer57's Avatar
57springer57
hd fomula+ gets my vote
Old Jul 19, 2011 | 05:05 PM
eazyduzzit's Avatar
eazyduzzit
Just curious.
Old Jul 19, 2011 | 05:19 PM
bp_shooter123's Avatar
bp_shooter123
Originally Posted by eazyduzzit
Just curious.
Look here
https://www.hdforums.com/forum/oil-a...ur-choice.html
Michael
Old Jul 19, 2011 | 07:17 PM
TwiZted Biker's Avatar
TwiZted Biker
Pardon my ignorance but when HD move away from Primary oil to the multi's ? I have no hands on with the twinkies so I'd like to get a bit educated here .
You Amsoil fanboys kill me but if that stuff floats your boat ... and before the flames fly I was in the industry for a while as well involved in very high speed high temp equipment I know more than a little about oil .
