TW6 Cam question
TW6 Cam question
I have always wanted to try Woods TW6 cams and just picked up a set on eBay at a nice price. Current 95" build is set up at 9.8:1 CR. Will the TW6 run good at the compression, or do I need to bump compression to 10.2 - 10.5? Will it be soft on bottom end at 9.8?
How you get from 9.8:1 to 10.25:1 is the trick.
Get with the people who did the work on your heads and discuss it with them. They can develop a plan to get you from point A to point B.
I just wanted to try a set of Woods cams based on what I have always heard.
I thought the 204's felt a little soft on the bottom end, but pulled great on top end. Last Friday, I had my heads cc'd to make sure I have the compression set up correctly for the new cams and found my heads were reading 84/84.5 cc's after being decked .020. Guy who did heads originally never cc'd them beforehand and was basing CR on 85cc HD spec. Due to the HD variance on the heads, my static compression was more in the 9.5:1 range rather than the 9.8:1 I was told by builder. This may explain some of the soft bottom end I felt.
If you go to the Big Boyz Twin-Cam Compression and Engine Displacement Calculator, http://www.bigboyzheadporting.com/TwinCamComp.htm, and input the 4* advance on that cam, you'll notice that the Corrected Compression along with Cold Cranking Compression will increase. You want your Static Compression up around 10.25:1, and Cold Cranking Compression between 190-200 psi. You'll need compression releases installed if you haven't already.
cycler
Engine Mechanical Topics
11
06-06-2019 04:23 PM
