Increasing compression with an Andrews 37
I have done some calculating on the Big Boyz compression calculator and have figured out I can get to 9.45 static, 8.9 corrected with my 4 degree cam offset, a .030 head gasket, and while getting the heads ported and flowed can get them milled to a 79CC cylinder head volume. When I do the jugs I could then go to the .040 gasket, flat top pistons, 95 ci jugs, and take out the 4 degree cam offset to get 9.7 static and 8.99 corrected compression which is what I have heard is the sweet spot for the cam.
Otherwise I can do the jugs first to 95 ci, domed pistons, and take out the 4 degree offset to get 9.76 static, 9.06 corrected then get the heads ported and flowed later without milling.
I guess the third option would be to do the jugs to 95 ci, flat top pistons, use the 0.030 gasket, and leave in the 4 degree offset to get 9.32 static, 8.78 corrected. Later do the heads with milling to 81 cc, 0.30 gaskets, and take out the 4 degree offset to get 9.7 static and 8.99 corrected.
Considering the options you outlined and limited by the fact that you can't do everything at once, the third option would be my choice.
Another option would be head work and a cam change; no big bore. Heads ported, decked and compression releases installed; set static at 9.4 (78cc chambers) and replace the 37 cams with a set of S&S 551s. The 37 is a popular cam and you could recover some of the upgrade cost by selling them on Ebay.
Nothing against the 37 cams; always a good choice but too many options to achieve the desired results IMHO. A cam replacement accompanied by the appropriate head work will get you the low end you want in one step and without the expense of boring cylinders and buying pistons; a cam replacement would cost about half of going bigger bore. However, if/when you decide to go bigger bore, you would need to replace the 551 cams with something like the S&S 570, or the Andrews 57 which is identical to the 37 but with more lift. Food for thought??
First question I have for you is about piston choice. If you have a 9.5:1 piston, that would indicate that static CR would be 9.5:1. Actually, to accurately compute compression, you will need to know the dome volume of the piston you are considering. However, assuming that the selected piston does produce static CR of 9.5, according to my calculations, leaving the 4* advance offset in place will result in corrected CR of about 9:1 and CCP of 185psi which is a bit on the conservative side but a very comfortable place to be.
So, you need to verify the dome volume of the 9.5:1 piston you are considering, run the calcs and see the results before pulling the trigger. You also need to consider that while the heads are off, it would be foolish to reinstall heads with 40K mile without disassembly, clean up, good multi-angle (SERDI) valve job and new guide seals. Once you see how much the head service will cost, you will see that spending a bit more gets you a set of decked and ported heads and you are back to considering whether or not to stick with the 37 cams or go for more cam. It's a conundrum.:icon-wink:
With out a doubt cubic inch is where it's at but you still need to make it work...
