New grips - to glue or not to glue
Old Feb 19, 2013 | 11:38 AM
jimjlips's Avatar
jimjlips
my grip came loose and it drove me crazy,I used super glue,it had to match the exact position of the other grip or I would be pissed off every time I looked at it
Old Feb 19, 2013 | 05:55 PM
hdbob2006's Avatar
hdbob2006
The left grip is
NOT held on by the switch hsng. It just slides on[and off] Try the hairspray-sounds like a good idea. I've used several different kind of glue,gasoline,tape... I can tell you what'll happen without some kinda sticky though-the first time the grip gets soaking wet,it'll spin loose.
Old Feb 19, 2013 | 07:25 PM
mjrobinson's Avatar
mjrobinson
No offense but I believe you are wrong. The left grip is held by the housing. There is a collar on the grip that goes inside the housing. Tighten the housing and it is not coming off. I've put 3 sets of grips on and never needed glue. However the hairspray thing is not a bad idea.
Old Feb 19, 2013 | 07:39 PM
RANGER73's Avatar
RANGER73
Your right, but, the grip twists a little and that drives me nuts.
Old Feb 20, 2013 | 12:02 AM
TheAddiction's Avatar
TheAddiction
I've always used hairspray on grips since my early days riding. I'm running kraton grips hairsprayed and safety wired like we use to do on our offroad bikes. If you don't at least use some kind of adhesive your asking for trouble. Ever had a grip come off in your hand?
Old Feb 20, 2013 | 12:10 AM
KingWalt's Avatar
KingWalt
I used golf club tape and hair spray. It has worked perfectly.
Old Feb 20, 2013 | 02:30 AM
Weevil's Avatar
Weevil
Originally Posted by semiret
I am tempted to not use the grip glue for the left (clutch) grip, but to just slide the grip on glueless. The grip seems to be held onto the bar by the switch housing, and not having it glued will make life much easier if/when I decide to swap the grips again.
So, my question - would I be OK, especially from a safety standpoint, to install the left grip without glue or am I missing something??
Thanks
Steve
I've got the Kuryakyn ISO grips and have been riding with the left grip unglued for about 2 years. Doesn't bother me a bit. I don't see any type of "safety" issue to it. And like others have and will say, hair spray is the way to go when installing them (Aqua Net comes to mind).
I'll tell you about the ISO's; the insides of the grips are slicker than owl **** and hard to clean. Almost like a light packing oil inside that's on the rubber padding. Which is why the left side grip on my bike is still not glued up. I'll fix it one day.
Old Feb 20, 2013 | 02:34 AM
Weevil's Avatar
Weevil
Thumbs up
Old Feb 20, 2013 | 03:24 AM
Tango69's Avatar
Tango69
Cool
Originally Posted by hdbob2006
The left grip is
NOT held on by the switch hsng. It just slides on...
No offense but I believe you are wrong. The left grip is held by the housing...
Actually you are both right.
They come both ways.
The pair I just bought doesn't go under the left housing but
it does have the built in throttle sleeve and goes under the right housing.
I didn't glue the left one on and it fit really tight and I tried twisting
it after I got it on and I couldn't twist it.
Old Feb 20, 2013 | 04:35 AM
Steve On 3's Avatar
Steve On 3
Survey says......hair spray........if it could hold up the big hair of the 80s...no prob with grips
