Turn signal indicators - relocation kit?
Old Mar 24, 2013 | 09:35 PM
Road Star's Avatar
Road Star
Default Turn signal indicators - relocation kit?
I cannot find the info on how to relocate the indicators for turn signals. I want to add an LED or something to my windshield, so I do not have to look down at the tank to see if I left the switch on.
Can someone please give me the correct terminology for this?
Thanks!
Old Mar 24, 2013 | 10:22 PM
Def Mute's Avatar
Def Mute
Your terminology should be accurate...
Although, I have not seen anything around that you're looking for. Why not just tap into the signal indicators under the dash, or at the front signals themselves, and run out to a connector (you'll need to disconnect if you remove your shield) and then to LED indicators that you select and mount on the shield? When replacing turn signal bulbs with LEDs, there is a need for a load equalizer. I don't believe it would be necessary when just adding an LED to the circuit. Just be sure you're not adding too many watts (which seems it would be difficult to do without trying IMHO).
RobV10
Jun 28, 2012 12:47 PM
97dyna
Jun 5, 2011 11:15 PM
TWIN CAM 96
May 5, 2011 03:52 PM
oscarg
Sep 14, 2010 10:08 PM
