Ever done this - stalled out, stuck in gear at a light?
Old Mar 31, 2013 | 06:47 AM
Bone Doc's Avatar
Bone Doc
Stalling the bike in traffic happens to everyone at one time or another. You should be able to restart it while in gear with the clutch lever pulled. It sounds like the clutch lever switch is not allowing you to start the bike. The clutch lever switch is considered a safety device to prevent you from trying to start the bike while in gear without pulling the clutch lever in. It is what allows the bike to start by pulling the clutch lever in.
Also it isn't unusual for new bikes to have difficulty finding neutral. That should get easier with time.
But (for safety reasons as you found out):
1. You should have been able to start the bike with the clutch lever pulled
2. You should have been able to push the bike in gear with the clutch lever pulled
Have you changed out the clutch lever? If it is the wrong lever, it may not have the "nub" on it that engages the switch to allow you to start the bike with the clutch lever pulled in. Have you opened the left switch housing recently? When reinstalling it, you may have pinched the wire to the switch. If not, it could simply be a faulty switch. Do you have too much play in the clutch cable? Maybe it is not fully disengaging the clutch preventing the bike from starting or getting into neutral or pushing it while in gear???
Old Mar 31, 2013 | 07:05 AM
mesquite's Avatar
mesquite
That has sure happened to me...I've just tried to remain calm and find neutral. it has been my experience that while the bike is rolling to a stop is the best/easiest time to find neutral
Old Mar 31, 2013 | 07:16 AM
davidwruth's Avatar
davidwruth
My 2011 Fat Boy had a bad switch that had to be replaced. Once it was fixed not a problem to start in gear. My 2013 starts in gear fine
Old Mar 31, 2013 | 07:21 AM
IronAss's Avatar
IronAss
Too much safety crap on bikes anymore. Some stupid *** lil switch goes **** up and you are stuck at some ***** house waitin for someone to bring you the part you need so you can get your bike started.
I'm surprised they don't have a switch in the seat that won't let you start the bike or put it in gear unless someone is sitting on the damn thing. Or a lock on the forks that won't let you turn them past 30 degrees unless the freakin turn signal is on.
Old Mar 31, 2013 | 07:25 AM
Greg Di's Avatar
Greg Di
If I start my 12 FXDC with the clutch pulled in, it starts no problem but it always lurches forward a couple of inches. Every time no matter what. Very weird.
Old Mar 31, 2013 | 07:33 AM
Bone Doc's Avatar
Bone Doc
Those features are probably coming down the pike. We all have to suffer because of morons that exist in this world. The clutch safety switch probably came to light because too many imbeciles tried to start the bike in gear without the clutch lever pulled. That is why all the MSF courses advise you to start the bike with the clutch lever pulled even if you are in neutral. On bikes with cruise control, the switch is also used to cancel cruise control when the clutch lever is pulled.
I would agree with your statement. But, I wouldn't recommend sitting in traffic (at a stop light) with your bike in neutral. It is safer to be in 1st with the clutch lever pulled in. If a car is approaching you from the rear and you have to evade them quickly, you are better off in gear, not sitting in neutral adjusting your *****.
Old Mar 31, 2013 | 07:34 AM
dc1450's Avatar
dc1450
On another note, while at a light, you should keep the bike in gear with the clutch disengaged (pulled in). Should some bonehead texting or something not stop behind you it makes for quicker getaway.
Old Mar 31, 2013 | 07:43 AM
M&P340's Avatar
M&P340
Yep, sure happened to me. I was sitting first at light in very heavy traffic recently, & leaned forward to take a look at my oil temp gauge. Helmet just tapped engine shutoff switch. I didn't realize it. Bike died, graveyard dead. I had no idea why. Hit starter button - nothing. I thought WTF????, as horns are blaring behind me. We had already sat through 3 cycles of the freakin light. Finally came to me, after plenty nasty remarks from cagers as they peeled out around me.
Old Mar 31, 2013 | 07:52 AM
rod18cdz's Avatar
rod18cdz
HAHA...I just spewed my coffee all over my screen. Is this speaking from experience?
Old Mar 31, 2013 | 08:16 AM
ChickinOnaChain's Avatar
ChickinOnaChain
Big Kahuna HDF Member
I've never had that happen...yet. The closest I've come to that would be killing it at a train crossing because the train was really long. But that's it.
