Road King/air shocks/tire pressure
Old Apr 7, 2013 | 12:33 PM
mesquite's Avatar
mesquite
Default Road King/air shocks/tire pressure
So, I'm a new Road King owner and I've read this forum a lot and really appreciate it. It sounds like I need to buy one of the pumps that Harley sells and do some experimenting with the air suspension. But as I've hears so many complaints about the difficulty of maintaining/checking air pressure in the rear tire. I asked my man and he said just remove the bag when you want to check it. I'm hearing the Harley gauge may also be used to keep the rear tire at the correct pressure...is that 40 PSI?
Old Apr 7, 2013 | 04:10 PM
hdbob2006's Avatar
hdbob2006
My bagger calls for 36# in both tires. I run about 20 in the rear shocks,depends on your weight and weight of passenger.
Old Apr 7, 2013 | 04:31 PM
GPHDXLC's Avatar
GPHDXLC
I ride solo only and keep the shocks around 12 to 15 to get the smoothest ride, but still not great.
Rear tire 36 lbs front 34 lbs, but this is just my self, may not be the best way but it's mine.
I love my King and I hope you will to.
Old Apr 7, 2013 | 04:43 PM
cobby's Avatar
cobby
2012 king, 36# front, 40# rear, 0 in shocks, I weigh 150.
Old Apr 7, 2013 | 10:46 PM
RK4ME's Avatar
RK4ME
The Harley air shock pump is a good one. Your owner's manual will have the pressure specs. I usually put my RK up on a Sears (yellow) motorcycle/ATV lift when I wash it, and I think that's the best time to check the tire pressure.
JimA
Apr 14, 2012 03:56 PM
bama6977
May 8, 2010 10:39 PM
sweet07
Mar 7, 2008 04:39 PM
vtxed
Jul 9, 2006 02:11 PM
daharleyrdr
Jun 10, 2006 03:03 AM
