Tire Cupping
Old Apr 25, 2013 | 08:20 PM
mattman22033's Avatar
mattman22033
My front tire was cupped on my 2011 RGU. The dealer said it was due to under inflation. Like I believe the dealer....lol. There is more to the issue than just under inflated tires. Way to many people have had tire cupping issues and the dealer is going to chalk them all up to low tire pressure. Harley knows there is an issue but choose to put the blame on the bike owner. I know I have had low tire pressure on my other HDs. It was not intentional but those tires never cupped. But yet on this bike it is low tire pressure....not the steering neck bearing being out of spec......not the wheel out of ballance....it's just plain old low tire pressure. That's right Harley don't take responsiblity....blame it on the owner.
JW1200's Avatar
JW1200
Cupping is due to not leaning you motorsickle, 99% of the time.
Old Apr 25, 2013 | 08:40 PM
SteveMKentucky's Avatar
SteveMKentucky
Originally Posted by oldairboater
I went through two sets of Metzlers on my wideglide. Cupping with both sets and my tires are never under-inflated, out of balance, and the suspension on my wideglide is tight. I think it is the tires but not a problem any longer. No Metzlers ever again.
On the other hand, I've run Metzlers on my BMW's for thirty years and have never had cupping. Hmmmm.
Old Apr 25, 2013 | 08:47 PM
JW1200's Avatar
JW1200
I can't wait to get me some new 888's !!
Old Apr 25, 2013 | 09:09 PM
Ridewva's Avatar
Ridewva
Cupping is the result of wear force from only one direction, which is why it occurs on fronts. The only wear force experienced by a front tire is resistance to forward travel, rolling resistance and braking. Rear tires deal with driving friction as well as braking. With this in mind some cupping of front tires is normal and harmless, other than a bit of howling noise when cornering.
As the front tire wears/cups it drifts out of balance (assuming it was balanced to begin with) resulting in irregular cupping. By this point the tire should be replaced.
Old Apr 26, 2013 | 06:48 AM
Steve On 3's Avatar
Steve On 3
Bad wheel bearings can do it too. Underinflation is the biggest culprit though.
Old Apr 26, 2013 | 08:26 AM
TwiZted Biker's Avatar
TwiZted Biker
Originally Posted by lo-rider
Cupping can be the result of under inflation, suspension problems and cheap tires.
About covers it , usually one side or the other on the forks is weaker or has different oil level .
Old Apr 26, 2013 | 10:47 AM
keith_stepp's Avatar
keith_stepp
In my experience, improperly inflated tires is the most likely culprit.
Old Apr 26, 2013 | 10:57 AM
mikelikesbikes's Avatar
mikelikesbikes
That will prolly be my next tire. I'll at least give it a try.
Agreed. Too many people do not check pressure often enough, especially with a quality gauge. As far as gauges you get what you pay for.
Old Apr 26, 2013 | 12:03 PM
Tampakingpin's Avatar
Tampakingpin
Originally Posted by Geoff
Cupping is due to under inflation and/or riding primarily on straight roads.
Keep leaning
