Pre-ride checks
Old Jun 27, 2013 | 11:24 AM
  #31
DPelletier's Avatar
DPelletier
commuting;
- check to see if there is fuel and the jiffy stand is up.
weekend ride;
- above plus tire pressures, check oil, suspension pressure, lights
road trip;
- as above plus check all oils and/or service if it's a long trip. give the bike a "once over" checking fasteners, belt, etc.
Dave
Old Jun 27, 2013 | 11:31 AM
  #32
DNC's Avatar
DNC
I suppose now that I think about it, especially for a longer trip (in addition to all of the above), I check the saddlebag bolts (aftermarket type) to avoid losing one or both of them on some highway.
Old Jun 27, 2013 | 12:09 PM
  #33
Geoff's Avatar
Geoff
I check with my hot neighbor lady to see if she wants to go for a ride.
Old Jun 27, 2013 | 12:19 PM
  #34
CB024's Avatar
CB024
Light Check. Horn Check. Fluid level check. Tire pressure check. Torque on critical fasters check. Clutch adjustment check. Throttle and idle cable check. Good to go.
Old Jun 27, 2013 | 01:03 PM
  #35
shucks's Avatar
shucks
Default Ditto
I just get on and ride. I'll make a more detailed check if I'm going on a long ride. But everyday back and forth to work and to the store. Nope...just jump on and go.
Old Jun 27, 2013 | 01:27 PM
  #36
oldairboater's Avatar
oldairboater
I do a walk around and look at the bike first. I mean really look. If I have checked the tires in the last few days with a gauge---I may just kick the centers and see how they feel. Do this enough and you can tell when a tire feels off. I look where the bike was parked and see if there is anything new that may have dripped on the ground. I will pull the dipstick and look at the oil, oil level and even smell it sometimes. I then roll the bike out to start it. I go through my start up sequence, which is the same but different for each bike. On the efi. I turn on the key, flip the run switch, watch the gauges power up and set. I listen for the fuel pump and the rush of fuel. I pull in the clutch and then light her off. I will put her back on the kickstand and do another walk around again while she warms up. I always warm up everything I start. Listening at her. Looking at her again including looking at the lights now. Basically two walk arounds and if something catches my eye I investigate further. The carb bike gets basically the same walk around. Startup is a little different. Turn gas on and prime her before lighting her off. I have to set the throttle screw to keep the rpm up around 1200-1500 while I do my second walk around. Ritual is almost the same since I was a young man. I have caught a few potential problems before I left the house by doing this through the years. It is automatic now and only takes a few minutes to do.
Old Jun 27, 2013 | 01:33 PM
  #37
DaveTheButcher's Avatar
DaveTheButcher
Same here, when I first got my street bob I'd check tire pressure before every ride along with lights, and signals, now, I ride every day but every ride is around 30 miles or less, so Ill just check tire pressure every few days along with the rest, If I plan to go on a longer ride Ill do the workup.
Old Jun 27, 2013 | 01:39 PM
  #38
Benway's Avatar
Benway
I'm terrible about pre-checks. Terrible. I do regularly check the oil and tire pressure, though. Should probably add a brake light check to that. If I had an older bike I might be more inclined to check the hell out of everything before a ride, but that's why I bought a newer bike.
Mostly, with this bullshit weather, I'm mainly checking if I'm gonna get my *** wet.
Old Jun 27, 2013 | 01:47 PM
  #39
Geoff's Avatar
Geoff
I'm proactive about checking my bike over. I don't wait until it's time to roll out of the garage.
Old Jun 27, 2013 | 03:24 PM
  #40
cmeaney's Avatar
cmeaney
I check to see if there is a puddle of oil around my bike
I check to see if there is enough gas to get to my destination
I check to see if there is enough money in my wallet for the end of the destination
Other than that-no
