I recently purchased a third party version of the o-ring shifter peg linked below. When received it is already assembled with the nut screwed on and since it freely rotates I cannot for the life of me get the nut off because the cap is already on the end and I can't pop the cap off to grip the bolt end. I thought that if I could take the nut off I could push the bolt through and pop the cap off. This way when I put it on I can properly tighten it.
Any suggestions on getting the cap off without damaging the finish? I have a small pick tool that I tried but the cap is flush against the peg.
Sure looks like the cap should pop off. Try putting a rag inside the jaws of a pair of channel locks, grip the cap and rock it side to side. Should pop out.
I don't know what would be under the cap, but if you carefully hold the threaded end of the shaft with a well padded vise grip you might be able to use a wrench to loosen the nut.
The HD version look like it has a notch where you could get a pic in to get it off. Since yours is flush you might try the end of a single edge razor blade to get underneath it. Be careful..
Maybe try putting a scrap nut on the end of the bolt and give that a tap. It should push the cap out enough to get a putty knife of something under the cap edge.
OK, this thing is driving me nuts. I'm providing pics for a better visual. The nut is tightened down and I can't back it off because the bolt spins freely. To access the bolt head I need to take the end cap off which is inset. I used a small pick and a razor blade and could not get it out but put a small scratch in it. This should have been a 30 second job. I also tried using small clamp with rubber tips to hold the end of the bolt and tried turning the nut, no luck.
Can you get a nut same thread, with some weld points or capped where it only grabs a couple threads, put a wrench on both nuts and loosen the one you're trying too.
