Oil filter O ring: Can you buy in bulk?
Old Sep 3, 2013 | 06:25 PM
  #31
xwhyz1959's Avatar
xwhyz1959
Originally Posted by caberto
OK... I just ordered a 90 pack of the AS568A Dash Number 013 from McMaster-Carr... but now I'm confused because of the other part #'s floating around... is this what I want for all 3 drain plugs in my 10 King?
I've been using a size 111 for years.
Old Sep 3, 2013 | 06:45 PM
  #32
Bocifus's Avatar
Bocifus
This is what I've been using on my 06 Deluxe. I don't use them on all three plugs.
Casey
Old Sep 3, 2013 | 08:43 PM
  #33
caberto's Avatar
caberto
LOL, OK, well that confuses things even further... what is a size 111???
Old Sep 3, 2013 | 08:46 PM
  #34
caberto's Avatar
caberto
Casey
Thanks Casey. That helps.
Old Sep 4, 2013 | 12:00 AM
  #35
Ron750's Avatar
Ron750
I got my rings in the mail tonight. They were the same size as the ones from the dealer. 20 for $2.15, including shipping.
That ought to last for a while.
http://www.ebay.com/itm/Harley-David.../180851948152?
Old Sep 4, 2013 | 06:36 AM
  #36
BMyers's Avatar
BMyers
I just ordered 100 -12 and 100 -13. I figure if I never use one size I am still money ahead.
Old Sep 4, 2013 | 07:22 AM
  #37
PPBART's Avatar
PPBART
The last 3 digits of the HD O-ring part # is the size of the O-ring… -013 is the cross reference size for HD pn#11105. McMaster-Carr has pn#9452K57 which is a bag of 100 for ~$2.50 and it is a Buna-N o-ring which will work just fine. If you want a Viton O-ring McMaster has pn#1201T24 which is a bag of 50 for ~$8.50… Personally, I use #41 Danco from Home Depot (9/16" O.D. x 7/16" I.D. x 1/16"), p/n 96755.
As for oil filters -- here's a cross reference for HD #63798-99A or 63731-99A:
• Purolator PL10241 / PL25230
• Mobil1 M1-102
Bosch 3330
• AMSOil SMF 133/134/135
• Baldwin B1413
• Hastings LF576
NAPA 1348
• Purolator ML16822
• WIX 51348,51215,51225 all spec.to 10-25 micron, not 5 as HD req.
• WIX 57348 chrome, 57148 blk. (info. Added 8/10 from HDtalking.com
• Champion PH7022 blk., PH2835 ch.
Old Sep 4, 2013 | 05:52 PM
  #38
xwhyz1959's Avatar
xwhyz1959
lol, ok, well that confuses things even further... What is a size 111???
7/16 id
5/8 od
3/32 dia.
Old Sep 6, 2013 | 08:24 PM
  #39
Sparkee...'s Avatar
Sparkee...
Go to a hydraulic pump supplier or repair shop. Here in Canada HyPower is the place to go. They know high pressure oil systems and how to properly seal them. They will give you the best match for any "O" ring at a reasonable price.
Old Sep 6, 2013 | 09:46 PM
  #40
skratch's Avatar
skratch
Originally Posted by mtgriz
Ok, I'm not against saving a couple bucks. I better take a look at some of these options. When you buy the orange derby cover gasket for the 10K service I suppose it's cheaper than $6 if those three o-rings aren't in the kit.
you don't really need to change the orange quad ring on your derby cover. i changed my primary fluid every 5k (not 10 per the manual) and i've gone over 40,000 miles and still on the same quad ring. no leaks.
thend
Oil Archive (no new posts)
Jul 28, 2017 02:24 PM
LimitedLou
Feb 25, 2012 07:51 PM
rfp1954
Apr 7, 2008 01:27 PM
rustyrun
Feb 18, 2008 12:28 AM
ORCUTTHD
Feb 12, 2007 05:51 PM
