Power Commander is here...I need a map
Old Mar 6, 2007 | 05:41 PM
anubisss's Avatar
anubisss
Default Power Commander is here...I need a map
For a bike with stage one big sucker a/f and some short Vance and Hines pipes. I guess the same as short shots will do okay as I don't see sideshots on their website. This afternoon is time for installation and adjustment. It is the IIIr model, not the usb. Any tips?
Old Mar 6, 2007 | 06:40 PM
HarleyWood's Avatar
HarleyWood
Default RE: Power Commander is here...I need a map
I'm not familiar with the IIIr...
mine is a IIIusb.
For a starting point you could try
If baffles are in
805-022
805-025
If no baffles
805-023
805-026
compare them and see how they look, load one and take'er out fer a smoke test
failing that its a crap shoot without a known good map or a dyno.
Where did you buy the PCIII?
You can contact Jamie at FuelMotoUSA and he'll probably have one in his library.
Old Mar 6, 2007 | 06:53 PM
Zyklon's Avatar
Zyklon
Try Power commanders web site, they list two maps 04 Softail with V&H Sideshots, try this link and look for map 805-184 and 805-186 It may not be exactly what you want but itmight be close enough for a starting place.
(Try these if you are running the stock ECU, if the ECU has the stage 1 flash then you might try Harleywoods suggested map.)
http://www.powercommander.com/805pciiiStk.aspx
Zyklon
Stickman53
May 29, 2014 09:05 AM
wrobo13
Exhaust System Topics
Apr 6, 2008 05:58 PM
Salperry
Nov 30, 2007 05:12 PM
Ace07FXDL
Jun 14, 2007 02:01 PM
iclick
25
May 3, 2007 11:29 AM
