I rode a Yamaha Road Star for 8 years before I went down in June. Picked up a stock '05 Heritage Softail Classic. MUCH smoother than my Roadie and a lot quieter. Looking at an '11-'14 Street Glide and I can't wait for a little more vibration and some more noise!
Well I had both my sales guy and the mechanic take it for a ride at the dealer. Sales guy said he felt a little vibration but nothing out of the ordinary, especially when compared to his Dyna. The mechanic which I feel really knows his stuff took it for a lengthy ride and said its fine. He recommended I go longer between shifting gears. He said he didn't shift into 3rd until around 45mph. I do it a little sooner than that. So I tried it on the way home and agree its better, but still think there is more to it. He recommended I keep an eye on, then when I bring it in for my 1K service, have them look at it again. IDK......I may take it to a local bike shop for a sanity check.
If you're riding 2 up you need to get the rpms up before you shift to get smoother and better power. Short shifting is hard on the motor and will cause more vibration. Don't baby it and don't run it like it's a 1950s john deere tractor.
My guess is that you're just not used to the unbalanced engine.
At idle, my Dyna vibrates like we're having an earthquake (although it's not stock which adds to that), but give it any throttle and it's smooth as glass & while cruising on the highway.
For what it's worth, when the GF and I got all packed up for Sturgis it had about 50 more pounds on her than I had ever done before. I looked at the owners manual and added the recommended air to the rear (about 45 lbs if I recollect). Got 30 minutes into the trip and noticed a considerable vibration that I hadn't felt before. Stopped and took the rear air down about 5 lbs and everything was smooth. Point is the ride seems to be somewhat sensitive to rear air pressure. Maybe take a look and adjust to see if anything changes.
FWIW, owners manual says 40 psi max for 2-up. 36 one up
That's on the older bikes. The newer bikes are recommended at 50 psi for heavy loads (two up riding or loaded down with luggage). But that is the absolute max. Going above that can blow the seals.
You sure about that? My 2013 is 40/36, same info I got from the dealer. I haven't seen any reccommendation for 50 psi on heavy load and I'm about as heavy load as it gets. Unless the spoke wheels tube tires run different.
Is that because of the newer fat riders and passengers?
What I don't understand is, why the 2013 Softail comes with the 103 engine WITH balanced crankshaft (103 B) and the Touring with UNbalanced crankshaft (103).. During my ride on rental Road Kings I noticed this shaking in idle or at low speeds. With my 88B block of my HC 2003 'Donky' I can even put a glass of water on the tank at idle rpm without spillage of water..
