Wet sumping
Old Sep 25, 2013 | 05:40 PM
xwhyz1959's Avatar
xwhyz1959
Default Wet sumping
Good evening my friends. A question about the phenomena of wet sumping. Are all HD motors suseptible to this, and how much oil can accumulate before it becomes apparent that it is actually occuring? Thanks in advance for your replies.
Old Sep 25, 2013 | 06:42 PM
heybaylor's Avatar
heybaylor
not exactly a phenomena....
it is the failure of a check valve , and the fact that the oil bag is higher than the crankcase...
how much ? until the crank cavity is full ,or the bag is empty.
btw the old two stroke HD's never did this
Harleycruiser's Avatar
Harleycruiser
We'll there has to be a oil pump or oil line problem, usally some trash going through the return part of the pump
Old Sep 25, 2013 | 06:47 PM
soft 02's Avatar
soft 02
Slap in a heavy duty spring and should stop the sumping.
Old Sep 25, 2013 | 07:05 PM
xwhyz1959's Avatar
xwhyz1959
You mean something akin to a Baisley spring??
Old Sep 25, 2013 | 07:11 PM
deadman77's Avatar
deadman77
Read the Norton forums if you want to learn about wet sumping. Common problem.
Old Sep 25, 2013 | 07:41 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Turn off the gravity thingee and there won't be a problem anymore. Could be a piece of debris in the check valve seat.
Old Sep 25, 2013 | 07:55 PM
hoethree's Avatar
hoethree
Please educate me, what IS wet sumping?
Old Sep 25, 2013 | 08:07 PM
soft 02's Avatar
soft 02
Sumping is when the oil that is supposed to be it the oil tank seeps by the valve in the oil pump down into the crankcase.
Old Sep 25, 2013 | 10:35 PM
TwiZted Biker's Avatar
TwiZted Biker
It's the big reason harley went to oil bag under the tranny instead of up in the frame like the shovels & evo's had , gets the oil lever below the pump & check ball so it doesn't bleed by .
