Remove pin striping
There is no ridge on the decal and you can see the paint has been cleared, as well as the decal.
The older models might not have been cleared but these were.
Sent from my XT907 using IB AutoGroup
You are probably right but these quotes may add to the confusion. Taken from some older threads from supposed painters and such....sounds like there was an activator & not a clear coat in 06-07.
"Started as a flat paint with no clear in 06, 08 they put a flat clear on it."
"Harley's black denim paints have to be bought through Harley (pricey) and can be bought as just a single stage or with a flat clear. They call for the clear on tanks, spilled gas could eat into the single stage, and for added UV protection."
"For 06 you need the HD Black Denim and the HD Activator.
No clear coat, no buffing, no wet sanding, no "flatteners", etc."
"Not a 100% positive but, the factory paint is Acrylic Urethane consisting of a Denim Black paint with Activator. This produces a very hard finish.
H-D also sells an Acrylic Laquer Denim Clearcoat that can be sprayed over Laquer paint or to repair over Urethane. This can be purchased in a spray can."
