More visible turn indicators
Old Nov 11, 2013 | 07:26 PM
Harleycruiser's Avatar
Harleycruiser
Originally Posted by TempoRubato
I've had my 2012 RK for a season now, and one thing always bugged me. I like to know for sure when the turn signals are on, but I didn't like having to take my eyes off the road to look down at the indicators. So I went to Radio Shack and got a couple chrome LED mounts with extra-bright white LEDs and mounted them in a more visible location. I tapped into the wires running to the front signals with a 390-ohm 1W resistor in each hot side. They are bright enough to see in the sunlight, but they're almost too bright at night. I may install a dimmer switch. http://i1312.photobucket.com/albums/...psadf008e3.jpg
Put a larger resister in to dim it for night, or put a high low switch with both resistors wired to it. Use double pole double throw. Much easier than a dimmer.
You can also get lower MCD rating and resistors built in.
Old Nov 12, 2013 | 07:04 AM
TempoRubato's Avatar
TempoRubato
What I had in mind was slightly simpler: put another resistor in series, and a SPST switch that shorts it out.
Old Nov 12, 2013 | 11:46 AM
Harleycruiser
Yea that is a better idea
vtchopperdude
Oct 27, 2018 06:44 AM
Train83
Sep 12, 2017 11:18 AM
beary
EVO
17
Jul 14, 2015 04:42 PM
aztsm
Oct 27, 2013 07:19 PM
Elvira
Feb 5, 2012 12:19 PM
