carb to fi
Old Mar 13, 2007 | 09:50 PM
wvtommy's Avatar
wvtommy
Default carb to fi
this may be a stupid question but has anyonereplaced there carbs with fuel injection if so is that expensive.
Old Mar 13, 2007 | 09:53 PM
DirtyDave's Avatar
DirtyDave
Default RE: carb to fi
NO. I know guys who have switched the other way. Carbs rule! FI sucks, no power, expensive to tune. One senser goes out and your stuck.
Old Mar 13, 2007 | 09:54 PM
xxxflhrci's Avatar
xxxflhrci
It would be cheaper to trade bikes.
Old Mar 13, 2007 | 10:00 PM
wvtommy's Avatar
wvtommy
no way i love my fatboy just would like to just start it and go not deal with that damm choke feal the same way about my 84 chevy pu
Old Mar 13, 2007 | 10:05 PM
DirtyDave's Avatar
DirtyDave
ORIGINAL: wvtommy
Still need to warm up the engine at least a little and take it easy on the throttle until the engine and drive train is warmed up. (Unless you like replacingbase gaskets.)
Old Mar 13, 2007 | 10:38 PM
ChopperHammer666's Avatar
ChopperHammer666
Saw this advertized in easyrider and VTwin TV:
Pegasus: The first truly rider adjustable electronic fuel injection system. $1,995.
Includes throttle body, air filter, fuel pump, petcock, pick-p assembly, coil and CD.
www.pegasusfi.com
Old Mar 14, 2007 | 02:59 AM
1200c's Avatar
1200c
The cost and work would not be worth it. There is no way that it could easily be done. You have a ton of parts that you have to find places to mount like fuel pump, oxygen sensors, throttle body, ecm, etc. etc. etc.
If you don't like the enricher, then get an automatic enricher. It will be a lot cheaper and easier then trying to go to EFI.
Old Mar 18, 2007 | 10:21 AM
wvtommy's Avatar
wvtommy
hey that sounds good first time ive heard of a automatic enricher thanks!
Old Mar 18, 2007 | 10:59 AM
monkyman's Avatar
monkyman
ORIGINAL: DirtyDave
How narrow minded
I'm not here to bash carbs because they do work well, but to say that FI sucks is rediculous.
They are more efficient.
As for no power, both carb and FI bikes are restricted from the factory, both need to be properly tuned, but FI IS more expensive due to the fact that you can tune it to every throttle position and RPM range to get max performance. A jet change can't do that.
There are also plenty of electronics on a carb bike that can fail just as easily as a FI.
I also just start and go, with no base gasket issue. what's that about?
Old Mar 18, 2007 | 12:37 PM
zukeeper's Avatar
zukeeper
you can get more power from FI than a carb , takes some teaking , but FI and more precise and fully adjustable.
