HELP...Lowering kit issues
Old Dec 17, 2013 | 02:54 PM
skullman77's Avatar
skullman77
6th Gear
Default HELP...Lowering kit issues
So I put a lowering kit on my 04 Heritage and now it has a rocking feeling, kind of like when your pulling a camper trailer, any ideas on why this is happining and how can I fix this? The kit is from arleness and just bolts on to the stock shocks. HELP...Lowering kit issues-user250228_pic196096_1376080331_thumb.jpg
Old Dec 17, 2013 | 04:14 PM
08Nighttrain's Avatar
08Nighttrain
On my bolts there are nuts on the front and back of the frame plate where you can adjust the hieght. Do you have the inside nuts tight up against the frame plate? sounds like there may be some play causing movement.
Old Dec 18, 2013 | 06:58 AM
oct1949's Avatar
oct1949
did you get the touring style or the leather that ties on lowers?
only thing I'd think is it has done is completely change your Aerodynamics of your bike causing it to react differentyl.
Old Dec 18, 2013 | 07:22 AM
24v's Avatar
24v
Huh?
skullman77- Could it be that you are bouncing off the bumpstops, and this is giving you the jerky feeling? How much did you lower the bike?
Old Dec 18, 2013 | 11:49 AM
skullman77's Avatar
skullman77
6th Gear
I sure there tight but I will re check them thanks
Old Dec 18, 2013 | 11:52 AM
skullman77's Avatar
skullman77
6th Gear
Originally Posted by 24v
Huh?
It could be, maybe I got it set to low then I will try bringing it up a bit.. I went down about 2 inches
Old Dec 18, 2013 | 03:04 PM
08Nighttrain
I went a little lower than 2" and I still have a bit of room before it hits bump stops. Sounds like something isnt right.
Old Dec 18, 2013 | 03:05 PM
korinmana's Avatar
korinmana
6th Gear
Could not see the pic. Dont have the rights?? Is it private?
troysterRG
Mar 19, 2017 10:35 AM
Steve Reiter
Mar 18, 2015 03:11 AM
FBLJosh
Apr 9, 2011 09:43 AM
SPERO56
Sep 11, 2010 06:06 AM
Toplink
Aug 20, 2010 10:06 AM
