Brake surging solved
Old Jan 15, 2014 | 11:22 AM
Big Erk's Avatar
Big Erk
Default Brake surging solved
Since day one my 2010 Street Glide has had a mild front brake surge that was more noticeable at slower speeds. After a bit of post searching and troubleshooting I discovered an interesting problem that I haven't read about and thought I would share what I found. The first thing I checked for was a warped rotor and found that both rotors had no noticeable issues. Second, I inspected the pads by removing the dust guard from the back of both rotors and both sets of pads had plenty of life left. Then I looked at both rotors from the front and that's when I noticed something. The left caliper looked off center and the rotor appeared to be rubbing against the inside jaw of the caliper. After I removed the caliper, I found my observations were correct. I thought to myself, "Is this a design flaw or is something not set correctly on the left fork leg?" Well, I decided to use the simplest fix and put some thin washers between the caliper and the fork mounting holes to move the caliper toward the center. It was just enough to clear and center the caliper. After a quick road test the surge was gone. So, if any of you are having this issue and haven't found a solution, this might be worth a try.
Old Jan 15, 2014 | 12:22 PM
Pete6114's Avatar
Pete6114
Good for you! And thanks for sharing
Old Jan 15, 2014 | 12:57 PM
Def Mute's Avatar
Def Mute
Did you think to check if the axle was installed correctly?
Sometimes, the axle is not pushed deep enough into the recess beneath the end cap on the front right fork, or the wheel not being pushed far enough onto the axle at the left fork, either of which can leave the wheel just a tad off center between the calipers. I will tap the axle from the right side of the bike into the fork tube, and then tap the left fork tube into the wheel/axle assembly, to ensure the axle is fully seated, before torquing the cap screws and axle nut fully.
Just a thought...
Old Jan 15, 2014 | 02:05 PM
Pete6114's Avatar
Pete6114
More good info. Thanks Def
Old Jan 15, 2014 | 09:05 PM
Big Erk's Avatar
Big Erk
Just a thought...
So, from what you are saying, the forks may be spread apart slightly. I didn't consider that theory because I didn't think they would move that much, but I guess anything is possible. I'll check that out Friday morning and report back. Thanks.
dkyork
Aug 4, 2024 04:21 AM
Buggz
Oct 11, 2021 12:38 PM
Houtzy53
Apr 15, 2017 01:59 PM
Race freak
Nov 7, 2011 10:19 PM
bbflhrs
Sep 26, 2010 09:35 PM
