How often do you service these items ?
I service the bike every 5,000 miles.
That includes changing all 3 lubes.
Then I go through everything else. Service is a misnomer. Most often you will check cables, brakes, clutch, front end, etc. and it requires no service. But I check it every time anytime
Once it is on the jack, it doesn't take long to go through everything.
I try to stay ahead of maintenance and upkeep.
But it might need a bit of tlc to start with...
Even though it was running fine,I like to check simple things like that. I'm glad I did-I don't know how long those plugs were in there,but much longer and they could have been a real problem to get out. And,I put a dab of never seize on the new ones.
I keep the old pair (or a new pair) in my tool bag, just in case.
Most of our vehicles have 4,6, or 8 cylinders so losing a spark plug isn't a big issue, but when you only have TWO and one gets weak or dies that puts a lot of load on the remaining cylinder.
I used to change my fluids every 2500 miles (using dino oils) but with the cost, and the longevity (supposedly) of the synthetic stuff I'm going with the 5,000 (or close to) recommendation.
i adjust my clutch every 5k when i do a engine/primary oil change.
the belt, i check the tension at every oil change as well. usually don't have to adjust it after the 1k adjustment.
i use shell rotella t in the primary (it is wet clutch certified) and i get it for $13 a gallon. at 38 oz per change, i get over 3 changes per gallon. with the clutch adjustment, and the primary oil change, the bike feels like a new bike everytime. you may think your clutch feels fine, but in all honesty, it's one of those things that change so slightly over time that you don't notice it. do an adjustment and i'll bet you'll notice the difference. like tires, notice how your bike rides so much better when she has new shoes?
spark plugs i usually just change every year. with the newer high detergent gasolines, and efi, plugs last a lot longer than they used to. but, it is a good idea to pull them now and again to look for oil fouling.
the fuel filter, well, honestly, i've never changed one on my bike. i wasn't having any fuel issues on my bikes, so i sold them with 40k on the original filter. just for reference, on my 2010 the manual recommended changing the filter at 25k. on my wife's 2012, the manual recommends changing the fuel filter at 100k. same filter, same gasoline. so not sure why they changed the maintenance interval.
I never adjust the clutch unless it starts to feel funny. (ie. starts to grab at a different point than usual) I'm not hard on the clutch tho.
I pull the spark plugs and change them every season. They are cheap and a fresh set will help fuel mileage with this corn syrup we have to use. I do the same thing for the fuel filter.
I also run a can of sea foam through the tank every 5K or so. I hate corn syrup.
