Tire Pressure
I became curious about my collection of tire pressure gauges. I also bought 3 new bourdon dial type gauges in three different price ranges: $75, $45, $18. Also bought a $13 digital gauge. These were added to my collection of pencil-type gauges.
These were tested against a calibrated mercury manometer capable of reading from zero to 32 psi.
Keep in mind the highest accurate test pressure available was 32 psi.
Of three "pencil" gauges: one was w/in 1 psi between 20 psi and 32 psi. The other 2 varied w/in 2-3 psi all over the place.
The $75 gauge was w/in .75 psi throughout the range [which was w/in advertised specs].
The $45 gauge was right on w/in the pointer width throughout its range.
The $18 gauge was off 1.5 psi on the low end, getting w/in .5 psi at the top end.
Amazingly the cheapo digital gauge was right on w/in its readout resolution [which was single pound increments].
Without the ability to accurately test higher than 32 psi might seem like a serious limitation. But for most auto/motorcycle tire pressures if a gauge read 'on' at 32 psi, I feel fairly certain that it is close at e.g. 40 psi [my Sportster rear tire, the highest pressure I care about].
These results were with the gauges I actually have. Another sample of the same models would likely yield different results [therefore I'm not mentioning brands/models].
BTW, with my recent obsession with tire pressures, I also tested tire pressure changes from 'cold' to 'warm'. It can be considerable. A discussion for another time.
Do it on all rubber tired vehicles I have and tire wear and performance is perfect, never have delamination problems, handleing or performance problems. Psi is checked often and correct at a minimum weekly.
So really there is no set psi for everyone. If people are serious about being safe and making our over priced (not my brand lol) tires last we would all find that magic for us psi where hot psi is 10% more than cold psi.
I have seen my brand of tire be shot in 2500 miles on other bikes by riders who swear the frame psi is perfect for all tires, while mine last 8-10K of aggressive riding, hell I have to change my brakes when I get new tires so I aint got time for under inflated dangerous tires. Might make a soft ride for sensitive behinds while sniffing flowers, but dont expect good tire life unless you run rock hard OEM spec tires (dont matter who makes them, Harley tire specs are horrible).
my 07 Heritage says....... 36 front..... 38 rear, solo,,, 40 rear 2 up.
