Any HD tech with transmission knowledge?
Old Apr 10, 2014 | 09:28 PM
Def Mute's Avatar
Def Mute
I stand corrected...
My old '99 seemed to be all steel. And the baker dd6 had hardened chrome finish on the forks, if I'm not mistaken. Gotta update myself sometimes!
I read most of your thread, interesting stuff!
Old Apr 10, 2014 | 09:38 PM
Zeus55's Avatar
Zeus55
Originally Posted by soft 02
Plenty of brass on my 6 speed forks. What tranny do you have?
6 speed Limited 2014.
The brass on the forks you're showing look very thin. It's a soft metal probably to protect the other harder sliding part.
I think the most important is not to have brass gears or bushings.
Old Apr 10, 2014 | 09:40 PM
soft 02's Avatar
soft 02
Like I said, I wouldnt worry about it. Been using a GL-5 for years and I dont think it caused the flaking on mine. Having 128k on the tranny had more to do with it. Not sure what a HD tech would have to say though.
Old Apr 10, 2014 | 09:41 PM
soft 02's Avatar
soft 02
Everything else is plastic caged roller bearings.
Old Apr 10, 2014 | 09:46 PM
Def Mute's Avatar
Def Mute
Just found the 'shift shaft sleeve' on the newer models...
My old '99 wasn't that advanced!
Old Apr 10, 2014 | 09:54 PM
Zeus55's Avatar
Zeus55
Ok than there will be no problem using a 75W90 GL-5.
Thanks!
I saw that you've took your's apart... what went wrong?
Old Apr 10, 2014 | 09:56 PM
soft 02's Avatar
soft 02
Thanks!
Weird vibrations in the engine were actualy every bearing being worn out in the tranny. Shoulda done it at 100k. It was pretty cheep to re build and easy.
Old Apr 10, 2014 | 09:58 PM
TwiZted Biker's Avatar
TwiZted Biker
Thanks!
Nope there won't be , think about it the old 4 speeds used several big brass bushing and regular gear oil for how many decades ?
Old Apr 10, 2014 | 10:02 PM
Zeus55's Avatar
Zeus55
In those days they probably did'nt know that the lub at over 185F was eating the gears.
Old Apr 10, 2014 | 10:16 PM
TwiZted Biker
Trust me having run the old ones since the 70's and I am a harley mechanic it doesn't have any impact on anything in your bike's trans. it would take years to begin breaking things down . Don't over think it , it's a non issue ........
